Boat slide?
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=64038
Author:  waggman [ Tue Oct 06, 2015 8:54 am ]
Post subject:  Boat slide?
Will an outboard with prop have less / prevent sliding on a mud motor smooth bottom hull?
Author:  BlueShamu [ Tue Oct 06, 2015 10:07 am ]
Post subject:  Re: Boat slide?
No.
Author:  Frog [ Tue Oct 06, 2015 3:57 pm ]
Author:  KJH [ Thu Oct 22, 2015 11:35 am ]
I have a smooth bottom mud hull (1852). I go back and forth between a 35GTR and a 60hp tiller outboard depending on what I'm doing. Although the boat was built for the mudmotor it handles great with the outboard once I got the motor height right. It doesn't slide much at all even if I turn when really hauling ass with the outboard. I suppose if I really drove it recklessly, I could get it to slide bad with the outboard.
It doesn't slide too bad with the MM either, but it does slide when I make sharp turns while cruising the backwaters at high speed.
Author:  deadbird8 [ Mon Nov 02, 2015 6:26 am ]
Chine design affects the sliding, not the flat bottom. Round chines or multi-taper will stick better at speed than a square chine.
Author:  Frog [ Mon Nov 02, 2015 7:05 pm ]
Author:  deadbird8 [ Wed Nov 04, 2015 6:26 am ]
Author:  Frog [ Wed Nov 04, 2015 1:43 pm ]
not to mention the outboard is acting as a deeper rudder with a prop that is pulling your stern around. As apposed to a surface prop pushing you with almost no rudder or skeg in the water.
