It is currently Fri Jun 27, 2025 1:39 pm
[ 10 posts ] |
Calimud88
 Modified grizzly
Well trying to make the best out of my grizzly for now till I can afford a prodrive hull. Right now I'm in the process of re enforcing the seats that I cut out. I'll most likely use for angled aluminum rivited around the outline of the seat then have it welded in. Next will be the wiring, going to mount a switch panel and run 1/2in- 3/4in liquidtite flex conduit under the gunnels. Then it's time to start building a blind out of 3/4in emt conduit, add hydro turf and finally apply the gator glide on the bottom of the boat. Season starts next week so hopefully I can get most the stuff buttoned up in a couple weeks.IMG_20151018_170254.jpg
Sun Oct 18, 2015 7:27 pm |
alexm
Joined: Wed Nov 24, 2010 5:07 am Posts: 276 Location: Miramar Fl
 Re: Modified grizzly
How much foam came out of that thing?
As is, do you think it's sturdy enough to stand on?
Mon Oct 19, 2015 12:08 pm |
Calimud88
Mon Oct 19, 2015 1:11 pm |
BERNIE255
Joined: Sun Jun 16, 2013 4:43 pm Posts: 1381 Location: Avoyelles Parish/ Marksville LA
How heavy was that foam that came out? Looking to do the same to my grizzly ams am interrested in seeing how you are gonna run wires under your gunnel
Mon Oct 19, 2015 5:20 pm |
Calimud88
Boats only a year old so no water got to the foam yet, wasn't to bad. I'm finishing up the bracing tonight, I'll lay out the conduit late an take a pic.
Mon Oct 19, 2015 6:03 pm |
alexm
Looks really good. Kind looking to do the same thing. And cut a bigger hole in the front to put the gas tank and battery
Mon Oct 19, 2015 8:13 pm |
Calimud88
Mon Oct 19, 2015 9:44 pm |
KRS62
I would stick with the 3/4 you already have it. Depending on how you make it the 1/2 will be too flimsy.
Tue Oct 20, 2015 8:32 pm |
Calimud88
3/4 is 2 big to mount under the gunnels. It's flex conduit so it's already somewhat flimsy, more clamps will solve that problem.
Tue Oct 20, 2015 8:55 pm |
Calimud88
Done for now, going to keep them open and line it with hydroturf and add some angle iron on the bottom so things won't slid out. Next time to start the blind and then electrical.
Fri Oct 23, 2015 9:10 pm |
[ 10 posts ] |
Users browsing this forum: No registered users and 156 guests |
