It is currently Thu Jun 26, 2025 10:37 am
Reply to topic  [ 16 posts ]
 Jerk rig in boat blind
Post Jerk rig in boat blind
How do you guys run your jerk line into the boat blind?
Do you cut a small hole in the side of the blind to run it through? Do you run it under all your material? I would think doing this would cause the blind to move around when you pulled the chord. I really don't want to cut a hole in that expensive blind material, but then again, I got it to kill ducks, not to look pretty.
Sun Nov 15, 2015 4:08 pm
Post Re: Jerk rig in boat blind
Depends on how the blind is set up. I built mine so the bottom part can move up and down some just for that very reason.
Sun Nov 15, 2015 4:11 pm
Through the drain plug hole. Keeps everything below the waterline...
17*38 Klibert 23GDLT
Sun Nov 15, 2015 4:15 pm
Sun Nov 15, 2015 4:20 pm
Professionals? Guess I better leave then! :D
Sun Nov 15, 2015 4:25 pm
Sun Nov 15, 2015 4:34 pm
Run a piece of pipe between the boat and blind and put the cord thru it so it dont move the blind
Sun Nov 15, 2015 5:21 pm
12 lb mushroom anchor with a carabiner through the eye. Sink it right next to the boat and run the line through the carabiner. The line will then run over the rail of the boat and then straight down, makes a 90º turn at the anchor, and heads towards the decoys. All below the waterline, no blind movement.
Sun Nov 15, 2015 11:50 pm
[quote="brstanle"]12 lb mushroom anchor with a carabiner through the eye. Sink it right next to the boat and run the line through the carabiner. The line will then run over the rail of the boat and then straight down, makes a 90º turn at the anchor, and heads towards the decoys. All below the waterline, no blind movement.[/quote
Winner winner! I will be picking up a mushroom anchor.
Mon Nov 16, 2015 12:20 am
Make sure you get a nice stainless carabiner that's good and smooth or else you'll part the line in a hurry.
Mon Nov 16, 2015 12:23 am
Mon Nov 16, 2015 3:17 am
VooDoo--what you get when you leave your Voo outside all night long.
Mon Nov 16, 2015 8:50 am
A pipe with an eye screwed into it is what I use.
a lot lighter than an anchor
Wed Nov 18, 2015 1:27 am
I've pulled the string around the bow of the boat so it goes underneath and run it over the back into the boat. Works fine unless you're on top of really heavy vegetation or mud. Doesn't visibly move your blind or cover either.
Wed Nov 18, 2015 5:33 pm
Admitting you use a jerk rig puts you in an elite category of waterfowlers, not an ersatz spinning decoy user with a remote SOB! :mrgreen:
Thu Nov 19, 2015 4:33 am
Thu Nov 19, 2015 7:57 am
Users browsing this forum: No registered users and 157 guests
