Go devil long tail vs surface drive hull https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=64691 |
Author: | jackh [ Mon Nov 23, 2015 9:23 pm ] |
Post subject: | Go devil long tail vs surface drive hull |
Maybe a dumb question, but what's the difference in the hulls? If I buy a used hull with a long tail on it already, could I plan to switch to a surface drive? Thanks. Sent from my iPhone using Tapatalk |
Author: | brycecheramie [ Mon Nov 23, 2015 9:41 pm ] |
Post subject: | Re: Go devil long tail vs surface drive hull |
Author: | brstanle [ Mon Nov 23, 2015 10:59 pm ] |
As far as go devil is concerned, the only non-size related difference is the chine shape. Their longtail hulls use a round chine, and their surface drive hulls use a single taper chine. Other than that, it's just the sizes that they're available in. |
Author: | da go get'er [ Tue Nov 24, 2015 1:02 am ] |
Author: | jackh [ Tue Nov 24, 2015 7:17 am ] |
I need to read up on chines, but does go devil do this because a round is chine better for a LT and single taper better for a SD? I thought I remember reading that gator Trax hulls were round chine and I always see them run with a SD. Thanks. Sent from my iPhone using Tapatalk |
Author: | brstanle [ Tue Nov 24, 2015 8:28 am ] |
To be honest boat width is the primary factor dictating a boats turning ability. Will a round-chine 44" bottom turn better than a taper chine 44" bottom? Probably a little. But a 44" bottom is going to turn waaaay better than a 60" bottom, no matter what chine is on either boat. I can enlighten you as to what go devil claims its reasons are, and it's that the taper chine offers more high-speed stability than the round, and since the surface drives are faster... that's how you get the surface drive hulls. I don't necessarily believe that, but that's the claim. Any of their motors will work on any of their hulls and will perform well, given the standard considerations (transom height, don't overpower a smaller hull, etc). |
Author: | jackh [ Wed Nov 25, 2015 10:39 pm ] |
Thanks for the info. Is this true of any of the big name mud hulls? They can take a LT or SD equally well? Sent from my iPhone using Tapatalk |
Author: | Hernaja1 [ Thu Nov 26, 2015 7:24 am ] |
Author: | dem0001 [ Thu Nov 26, 2015 12:09 pm ] |
I run a 35 go devil surface drive on one of their 18x44 hulls with round chines. No complaints so far. Can handle up to 4 guys no problem. Turns on a dime. I got the round chine model because I run a lot of tight, winding rivers. Sent from my iPhone using Tapatalk |
