It is currently Fri Dec 19, 2025 7:46 am
Reply to topic  [ 9 posts ]
 cut seat in a jon boat
Post cut seat in a jon boat
im thinking of cutting my back seat out of my bot and making two half boxes. How would this wreck my bracing in the back of my boat? I know i would need to brace the inside of the seat after I cut it so that i would be able to stand on it. I know my foam is holding water and I would like to free up some weight.FullSizeRender.jpgFullSizeRender3.jpg
G3 project boat
Thu Jan 28, 2016 9:29 am
Post Re: cut seat in a jon boat
i forget the fellas name but he sent me these from his boat. I wanna say he either used aluminum he cut out to box in the open sides or just ply wood..
Also north la hunter did some nice work on one of his boats. He may chime in
Thu Jan 28, 2016 9:36 am
Sent from my beeper
Thu Jan 28, 2016 10:24 am
We cut everything out of this boat and put deck and gun box in it. Started as a plain Express Jon boat. It's the same boat as the picture above before I cut the seat out.
Sent from my beeper
Thu Jan 28, 2016 10:26 am
My boat is riveted will that cause any problems?
G3 project boat
Thu Jan 28, 2016 11:08 am
Thu Jan 28, 2016 1:38 pm
I've removed all the seats from riveted boats, with ribs, from 18 to 24 feet long. They will flex and twist a lot without the seat/seats to act as a thwart. The reason for removal is to add floorspace for carrying a load. The real danger is if you get in rough water the flex will bow out the sides and the boat will actually fold up in the middle. The remedy that we have used for many boats and has never failed us is to bolt a good Cedar 2" X 4" immediately below the gunnel, either inside or outside, the full length of the boat. On the 24 footer we use a 20 foot 2 x 4 and use stainless hardware with fender washers every 16 to 18 inches. It takes the flex out of even a 24 footer. We have never had a flex issue with welded boats and longitudinal stringers in the floor.
Thu Jan 28, 2016 6:26 pm
Fri Jan 29, 2016 7:10 am
G3 project boat
Fri Jan 29, 2016 12:39 pm
