It is currently Wed Dec 17, 2025 1:16 am
Reply to topic  [ 22 posts ]
 best way to put gator glide on
Post best way to put gator glide on
I am going to put gator glide on the bottom of by gator tail 1854 extreme. Its a open floor boat.
I can remove the engine and battery and flip it over to paint the gator glide on or just pick the boat up and suspend it from a hoist and paint the bottom. Question is , Is it worth the hassle pulling the gtr 35 off to pain the bottom
1854 gtb extreme pushed by a stock 35gtr from south east gator tail
Wed Dec 28, 2016 8:17 pm
Post Re: best way to put gator glide on
I suspended mine with a hoist and rolled it. It went quick and easy.
Wed Dec 28, 2016 8:31 pm
I do both. If you have a way to safely flip it, it will be easier to sand , clean and apply. But like pas tout la said it not that tough from underneath either. Always leave yourself a way out if your lift system fails. I use 5 gal buckets full of sand with a 4"x4 "and or a 30 drum
http://www.gatorglide.com/
gatorheads@comcast.net
Thu Dec 29, 2016 8:57 am
I will be doing this as well when my 1750 is finished being build. I want to suspend it but do you guys have any suggestions as to where to connect the straps... IE.... what fitting will hold the boat with the 4400 HDR on it without putting straps under the boat where I will be painting.... I was thinking of lifting the stern off the trailer and drive the trailer forward so the bow of the boat would be held up by the back of the trailer. I have a 6k winch system so the winch isn't in question,,, just where to put my connections on the boat to lift the sucker..... any advice?
Lead, Follow or Get The Hell Out Of The Way!!!!
1754 Gator Trax Hybrid, Hunt Deck ,with MB 4400 Black Death HDR, Duck Slaying, Mud Slingin Machine!!!
Wed Jan 18, 2017 2:30 pm
Profile YIM
Only takes a few minutes to pull a motor off the boat. I flipped mine upside down and backward on the trailer so I could still move it around in the yard to get good sun on it to cure the first day or two. I'm due for some fresh GG after the season is over myself.
-Custom pool noodle
-stage 4 water wings
Wed Jan 18, 2017 6:12 pm
Thu Jan 19, 2017 5:12 am
1854 Prodigy DPE Level 3 HDR
Thu Jan 19, 2017 5:31 am
Thu Jan 19, 2017 10:47 am
Is GG beneficial for small boats, say under 13'?
2017 Atchafalaya Outdoor Designs 1244
2017 Copperhead 12hp
Thu Jan 19, 2017 10:54 am
Thu Jan 19, 2017 11:38 am
Put it on my brothers pirouge. He said it worked real nice for sliding off cypress knees. Only thing he doesn't like is when he almost bust his ass getting into it on bank, It will slide out from under him.
Fri Jan 20, 2017 11:25 am
Fri Jan 27, 2017 1:27 pm
Profile YIM
Sun Jan 29, 2017 8:38 am
Profile YIM
Sun Jan 29, 2017 10:12 am
Mon Jan 30, 2017 9:26 am
To the guys that have flipped their boat... I have a 1754 open layout. Do you think a few guys will be able to flip it or would i need an engine lift or something to flip it?
Fri Feb 03, 2017 8:32 am
Figure with nothing in the boat on 600 pounds. Could be more or less, but not much less if built decent. Plan your help accordingly.
Fri Feb 03, 2017 8:49 am
Fri Feb 03, 2017 3:06 pm
I had a work truck with a 6Klb crane. Flipped it easy. Then re rigged and picked the whole boat up and sat it on the trailer upside down. I'm sure if your method of hoisting the boat is stationary, you can just pick it up off the trailer, roll the trailer out, flip it and pick it back up and set it back down on the trailer. I did this so I could move the boat while letting the GG finish curing.
-Custom pool noodle
Fri Feb 03, 2017 3:31 pm
Pay someone to do it that has the equipment and expertise.
18X44 Geaux Custon Powered By MB 4500 BD
Fri Feb 03, 2017 4:10 pm
Plenty of ways.
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
Coupe rest in peace brother
Fri Feb 03, 2017 4:47 pm
Old timer engineer made this to flip his 17' by himself. Said he was in his 70s and stood 5'4'. He also said "use your head instead of your back, Its just that simple!" . I thought it was pretty cool!
Wed Feb 08, 2017 8:10 am
