It is currently Mon Jul 14, 2025 7:18 pm
[ 6 posts ] |
Delta Goose
 PD Prop bushing
In most cases when the prop is removed the taper bushing will remain in the prop. To remove the bushing use vise grip pliers or channel locks as shown below to compress the bushing and twist slightly....Tried this just not working. Any special way of getting this bushing out or trick. This is my first PD any help would be great.
Tue Feb 12, 2013 1:51 pm |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
 Re: PD Prop bushing
new prop? you should use a new bushing
_________________ I gave up mud motors
Tue Feb 12, 2013 1:52 pm |
Delta Goose
 Re: PD Prop bushing
Old prop took it off to grease everything.
Tue Feb 12, 2013 1:56 pm |
Will
 Re: PD Prop bushing
Get a bigger pair of pliers, if there is enough bushing sticking out of the prop, you can squeeze it and get it out, if not drill a hole in the bushing directly across from the groove that is already in it the lentgh of the bushing (basically drilling another grove on the other side) it will come out easy then.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
Tue Feb 12, 2013 2:04 pm |
Delta Goose
 Re: PD Prop bushing
Thanks
Tue Feb 12, 2013 2:09 pm |
bayouboy
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5376 Location: Venice, La
 Re: PD Prop bushing
Mon Feb 18, 2013 11:21 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 50 guests |
