It is currently Tue Jul 08, 2025 6:30 pm
Reply to topic  [ 33 posts ]
 Prodrive prop hitting transom?
Post Prodrive prop hitting transom?
I just purchased a brand new 36 hp prodrive. Its a tall transom engine.
i had it on a 19.5 inch transom, and the engine seemed to do pretty good in reverse. I swapped boats, and the transom on my new boat, is 21.5 inches. it doesnt seem like much of a difference, but theres a big difference when in reverse. I dont get as good of a grab in reverse with the taller transom.
Before i decide to cut the transom or make any modifications, can someone help me? maybe give me info on whats the best thing to do? Would cutting my transom down 2 inches be the best thing to do? Any info is greatly appreciated! Thanks again!
Mon Feb 18, 2013 2:16 pm
Post Re: Prodrive prop hitting transom?
Pro-Drives are designed for a 19.5" transom. If you want the best performance out of your motor, thats what your transom height needs to be.
Mon Feb 18, 2013 2:22 pm
so, best bet would be to cut the transom down right? i wouldnt be able to think of anything else thats better.
Mon Feb 18, 2013 2:29 pm
Or a 3 blade prop. Blades are shorter
Mon Feb 18, 2013 2:51 pm
I really had the visual that the actual cavitation plate is supposed to go under the boat. am i right? or is it supposed hit the transom?
Mon Feb 18, 2013 2:56 pm
My cav plate rubs the bottom of my Prodrive boat/stops prop from hitting
Mon Feb 18, 2013 3:02 pm
wrong transom height...your gonna have to cut it down. There is nothing else you can do. well you could buy a boat with the correct transom height or cut yours down.
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Mon Feb 18, 2013 3:07 pm
So, it should be cut down to 19.5 inches. and my cav plate should be able to go under my boat?
Mon Feb 18, 2013 3:08 pm
How many more times do you need to be told the same thing. :)
17x48 extreme stage 2 GTR
Mon Feb 18, 2013 3:11 pm
lol delta. I have a buddy who has a 27 and his cav plate doesnt go under the boat. some say it should be like that, and others say it doesnt. im just trying to make sure before i do some cutting and fabbing up.
Mon Feb 18, 2013 3:13 pm
call prodrive, they will tell you.....trimmed all the way up when you spin the lower unit, cav plate and all go under the boat....you can trim down a little but you dont want the cav plate rubbing or its hard to steer. Whatever anyone tells you it dosent matter, you should always go with what the manufacturer tells you.
Mon Feb 18, 2013 3:16 pm
Thanks, thats what i was looking for. i appreciate it!
Mon Feb 18, 2013 3:18 pm
It will put a dint in the back of your boat if not a hole trim it up . I fount out the bad way
Mon Feb 18, 2013 5:53 pm
I have a PD X-series boat an if u trim the motor down too much it will hit the back of my boat in reverse u just have to figure out how low u can trim it
Stage 2 36 HP Pro-Drive FPR W/ Bayou Boys Custom Skeg,Cave Plate,and Weed Cutter with MAC Exhaust
Pushing a 17X54 Pro-Drive X-Series boat
Mon Feb 18, 2013 6:19 pm
20" max for a PD.
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Mon Feb 18, 2013 6:36 pm
I'd go 19 and then you will be able to shim it back up 1/2" if necessary. Every boat will run different even if they were popped out the same mold. I have a boat in the yard that runs best at 19 inches.
Mon Feb 18, 2013 7:06 pm
what about transom angle. Are they different. I have seen the wrong transom angle do this.
Tue Feb 19, 2013 5:58 am
I agree it would make since for it to go under the transom but I have a Prodrive (factory) boat and motor with 21" sides and the cavitation plate will hit the back of the transom about 2" from the bottom, they even have a double layer of aluminum in that spot for added protection. Bug has one with 18" sides with a taller transom, same thing... These are factory built Prodrive boats for Prodrive tall transom motors. It's basically up to you if you want to cut or not, to each his own...
Tue Feb 19, 2013 6:20 am
I had a factory pd and my prop or cav plate never hit my transom if i was trimmed up all the way....when i trimmed down to get more push instead of lift it did.
Tue Feb 19, 2013 6:22 am
Correct, you can trim down to where the top of the motor is just about level before it hits....
Tue Feb 19, 2013 6:27 am
wonder if those with the small rake at the bottom of the transom have this problem. The rake is about 3" up, might miss it.
Tue Feb 19, 2013 6:50 am
cav plate might not hit it but prop would......
Tue Feb 19, 2013 6:57 am
Tue Feb 19, 2013 11:01 am
Tue Feb 19, 2013 12:11 pm
Tue Feb 19, 2013 12:55 pm
It works really well, I have a few different designs out, but this is one of the better performers. When you lift up it has more room to clear its self and the longer/ higher rake lets more shit slide under it rather than piling up in front. Also if you look at the pic above that motor has a 1/2" spacer between the transom and the clamp. This also allows you to make the front the skeg longer. This combination of skeg and modified cav plate work very well together and weed cutter turns a normal props salad into coleslaw.
Tue Feb 19, 2013 1:01 pm
Had same issue with a PD and gator trax lived with it for a year and had KP cut it to 19.5" Now I kick myself for screwing around with it for a year.
Tue Feb 19, 2013 4:24 pm
Now im thinking about putting a jack plate on the boat. It'll set the engine back only 3 inches or so, and i will have it to where it will be dropped 2 inches or so. anything good or bad about a jack plate for a prodrive? its not hydrolic or anything, just something to lower the engine!
Sun Feb 24, 2013 11:48 am
Just cut your transom down. Uncle J is doing it for me now. Its not worth fooling around with the jack plate.
Sun Feb 24, 2013 12:00 pm
Want to bring this back up. Building my new rig in shop now. What actually is the best transom height for a PD 36 long shaft?
Tue Mar 26, 2013 1:40 pm
19-19.5, imo
Tue Mar 26, 2013 2:58 pm
Pro-Drive will tell you 19.5
Tue Mar 26, 2013 3:42 pm
10-4
Tue Mar 26, 2013 8:10 pm
Users browsing this forum: No registered users and 58 guests
