bigjohn33
 Trim problem on gator trax
I have a question guys, On occasion my trim has quit working, but always started working again. Even when its not working, it's getting power...making a relatively loud clicking almost? Any thoughts on this I believe the unit is a wearner?? It is an 07
Wed Apr 10, 2013 8:15 am |
TX Aggie '06
Joined: Mon Jul 26, 2010 4:32 pm Posts: 684 Location: Houston TX
 Re: Trim problem on gator trax
Are you asking about the trim on your motor? Assuming mud buddy?
If that is correct sounds like you have a corroded trim relay/circuit breaker and just needs replacing.
Sent from my MB865 using Tapatalk 2
Wed Apr 10, 2013 9:12 am |
bigjohn33
muddbuddy correct.
How can I replace/refurbish the relays? I am not very savy with that kind of thing...any help would be appreciated
Wed Apr 10, 2013 9:17 am |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
Look on back of starter. Should be 2 small circuit breakers with yellow plastic caps. You can buy a replacement from any parts house for about $5 that'll last you a couple months, or you can order new breaker from Boat Dr for about $20 that'll last you couple years.
Easy to replace. Just need 8mm socket, 10mm & 3/8 wrenches.
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Wed Apr 10, 2013 9:32 am |
bigjohn33
when you say a parts house, like a auto part place or a bosting store?
Wed Apr 10, 2013 9:54 am |
Team Camo
Auto parts. It's a 20 amp breaker
Wed Apr 10, 2013 10:04 am |
bigjohn33
so all in all hopefully a pretty painless fix..anything else to know before I attempt ha
Wed Apr 10, 2013 10:29 am |
TX Aggie '06
I think the bottom breaker is the trim and the top the clutch. You should be able to tell the bad one (rusty or corroded).
Other than that do what Camo says and you should be good.
Wed Apr 10, 2013 11:05 am |
bigjohn33
thanks guys, I will try to do that this weekend.
Wed Apr 10, 2013 12:08 pm |
SCmudder7071
I've had breakers from Napa on my motor for about 80 hours with no problems.
_________________ 1754 Extreme/LAProp Stage 2 GTR
Wed Apr 10, 2013 12:38 pm |
Team Camo
Wed Apr 10, 2013 1:46 pm |
