It is currently Tue Jul 08, 2025 6:37 pm
[ 6 posts ] |
im replacing trim unit on mudbuddy
bigjohn33
Hey fellers, IT has gotten to the point where I must replace my old bear trim unit (surprised it lasted this long) a 2006 mudbuddy 29hp. My question is should I go with the Thompson unit that is a couple hundred dollars or try and upgrade to the mercury 800$
I only put 15-20 hours on the boat a year so I want to take that into consideration.
Also can the Thompson trim be put on without pulling the motor off?
Thanks
Tue May 14, 2013 8:08 am |
Z71v2.0
Joined: Thu Mar 17, 2011 12:06 pm Posts: 605 Location: The Promised Land of TX
 Re: im replacing trim unit on mudbuddy
Get the merc. Why spend a couple hundred? Spend the rest for the merc and be done with it
_________________ THIS SPACE FOR RENT
Tue May 14, 2013 8:10 am |
SCmudder7071
To change to the Thompson all you have to do is change the slides. I finally swapped to the Merc after going through 4 Thompson's within a year. They were all under warranty thank goodness. The Merc is where it's at.
_________________ 1754 Extreme/LAProp Stage 2 GTR
Tue May 14, 2013 8:37 am |
tinman454
Joined: Mon Feb 07, 2011 10:47 am Posts: 732 Location: Ontario ,Canada, eh!
From what I here you are much better off putting on a merc trim. Are you planning on keeping the motor for a few years? If not just put a Thompson back on. I you are planning on keeping the motor bite the bullet now and go with a merc trim.
_________________ 08 35 mudbuddy, gator traxx 3 man hide.
Tue May 14, 2013 8:47 am |
bigjohn33
Are changing out the slides difficult?
Tue May 14, 2013 2:11 pm |
SCmudder7071
4 bolts. That's it.
Tue May 14, 2013 3:32 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 61 guests |
