It is currently Mon Jul 14, 2025 7:52 am
Reply to topic  [ 10 posts ]
 Gtr lower unit
Post Gtr lower unit
Was cleaning off prop today and noticed a very small amount of grease between the prop and the shaft housing just wondering if it's normal thanks
Fri Apr 25, 2014 11:29 am
MMT Moderator
Post Re: Gtr lower unit
I have never noticed grease coming from there sounds like a seal issue. You do put new grease into your lower unit right? And before doing so you remove the set screw that allows the old grease to come out before the seal/prop.
GTB 1860 w/ 2019 GTR40XD-HO
Fri Apr 25, 2014 11:41 am
From time to time a little grease seeps past the rear seal. It's perfectly normal. Depending on how you were running and for how long, you may or may not see it back there.
Just make sure you pull the screw out like WEA said when you grease it.
17x54 Extreme W/ GTR-35L Stage 1
Fri Apr 25, 2014 11:44 am
Yes I always take the screw out before pumping new grease and I just did it the other day again
Fri Apr 25, 2014 11:50 am
Like i said, it's normal.
Fri Apr 25, 2014 11:57 am
Sounds good thanks
Fri Apr 25, 2014 12:15 pm
MNGtail - it does only sound like normal seepage, but I got a few ? for you.
what year is the motor?
how many hours you got on it?
do you use AMSOIL grease, when you change grease do you notice a lot (any) water contamination in old grease?
thanks
BV
Fri Apr 25, 2014 12:36 pm
It's a 2013 56 hrs. and yes I use Amsoil
Fri Apr 25, 2014 12:47 pm
Guess I just never noticed it before
Fri Apr 25, 2014 12:49 pm
Mine did that from 40 hrs till i sold at 176, just a Lil would show, but never had any water. No biggie
Fri Apr 25, 2014 12:55 pm
Users browsing this forum: No registered users and 43 guests
