It is currently Mon Jul 07, 2025 4:06 pm
Reply to topic  [ 11 posts ]
 GTR transmission swap out
Post GTR transmission swap out
I have to change out the transmission on my 2015 GTR due to a leak. Was wondering if there is diagram somewhere that I could use for reference to be sure that I do everything right. Really do not want to do it by trial and error but will if I have to. thanks in advance for any help
Sun Dec 28, 2014 11:58 am
Post Re: GTR transmission swap out
if its a 15 you should have a warrenty on it
07 16x50 w/ 07 35 gtr
Sun Dec 28, 2014 12:01 pm
It is under warranty and GT sent me the part but I do not have a dealer close at hand. It does not appear too difficult but would feel more comfortable with a little direction.
Sun Dec 28, 2014 12:25 pm
Maybe millers in Ocala could help if you didn't want to do it urself.
1754 GTB / 35 GTR
Sun Dec 28, 2014 12:50 pm
i dont believe its much to it just take the bolt off and use a puller to pull it off think you suppose to drain the fluid out first before removal
Sun Dec 28, 2014 1:03 pm
Drain fluids from planetary, remove caliper. One bolt removed from planetary. remove outer planetary pull buy hand can rotate to help, 5 Allen heads takes off second side of planetary. That's it red loctite on reinstall! !!!
Sun Dec 28, 2014 8:18 pm
Maybe this will help.
Sun Dec 28, 2014 8:23 pm
That will help! Thanks. I hope I don't run into as many issues as he did, lol. That is exactly what I am trying to avoid. I am definitely not a mechanic
Sun Dec 28, 2014 8:48 pm
Yeah that guy didn't get it at first obviously. Just give me a call and I'll run you threw it jess
Sun Dec 28, 2014 8:57 pm
Thanks to Dmax I was able to get everything apart until it came time to remove the outer geared shaft. I understand it has a keyway or spline and should pull off but I used some force and it refused to budge. Dmax has never done this specific one so I need to know if there is a trick to removing it? Thanks in advance for your help.
Thanks again to Dmax for taking several phone calls from a perfect stranger on a Sunday afternoon. I appreciate it!
Sun Jan 18, 2015 6:11 pm
No problem jess, glad I could point you in the right direction
Fri Feb 06, 2015 9:22 pm
Users browsing this forum: No registered users and 36 guests
