Stainless Steel props?
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=28759
Author:  david95 [ Wed Apr 25, 2012 8:23 pm ]
Post subject:  Stainless Steel props?
Im wodering if a stainless steel prop will make a difference on a 15? Thanks for any info.
Author:  Woodiebuster [ Wed Apr 25, 2012 9:37 pm ]
Post subject:  Re: Stainless Steel props?
Do what?
Author:  david95 [ Thu Apr 26, 2012 7:51 am ]
How much of a difference with a stainless prop compared to a aluminum prop?
Author:  msm8281 [ Thu Apr 26, 2012 8:23 am ]
Author:  david95 [ Thu Apr 26, 2012 8:41 am ]
Msm, alright i appriciate it.
Author:  mizzippi jb [ Fri Apr 27, 2012 9:43 am ]
A 15 outboard? All mm's have (or should have) steel props.
Author:  david95 [ Fri Apr 27, 2012 10:34 am ]
Author:  WAD SHOOTER [ Fri Apr 27, 2012 10:53 am ]
Don't do it. Waste of money and can cause major damage. The thing is stainless props are only good on higer hp motors because aluminum props tend to flex with the higher hp. A smaller hp like your 15 wont make any difference. Also if you hit something with the stainless hard your looking at bending or breaking your prop shaft and seals. With an aluminum it will just chip off.
Author:  david95 [ Fri Apr 27, 2012 1:59 pm ]
Author:  bobbyjober [ Fri Apr 27, 2012 4:56 pm ]
Man for real? too much prop and will break a shaft? In fact get right diameter and pitch it will perform better since an aluminum does lose pitch due to flex when in use. as for breaking a shaft, not gonna happen, there is a rubber bushing that will slip before breaking shaft.
Author:  WAD SHOOTER [ Fri Apr 27, 2012 10:05 pm ]
Author:  duckduckboom [ Fri Apr 27, 2012 10:11 pm ]
I have a 40 merc and the aluminum prop is a spare to the stainless
Author:  Woodiebuster [ Fri Apr 27, 2012 11:36 pm ]
Yeah, okay :roll:
Tell that to the hundreds of people around here who put their outboards through hell in the stump fields with stainless props. I've seen the prop spin out, get bent, and even the lower unit get torn off. But never shaft or seal damage because of a stainless prop.
Author:  wm [ Sat Apr 28, 2012 7:38 am ]
ive rebuilt 5 lower units thats a small percent but they have all had broken lower unit gears or broken shafts do to hitting stumps and rocks using stanless steel props i also read that some of the manufactures are starting to void warrantys on small motors if a stanless is put on and their is a failure in the lower unit
Author:  centxhunter [ Sat Apr 28, 2012 7:42 am ]
Plus, you can rebuild an aluminum prop easily. SS, not so much.
Author:  pooldoo73 [ Wed May 23, 2012 1:37 am ]
The first thing we do wif a new o/b is put a stainless wheel on it. Aluminum is good for lake boats. Sand eats an aluminum prop in seconds. Lillies will even twist the blades all up.
Author:  CLICKSTER [ Wed May 23, 2012 5:47 am ]
so your saying a 3 cyl 40 merc can flex a stainless prop? thats your ass. them little motors got tons of ass!
