Help removing prop shaft https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=31116 |
Author: | rob_E [ Sun Jul 29, 2012 11:58 am ] |
Post subject: | Help removing prop shaft |
How do you remove the prop shaft on a gator tail surface drive |
Author: | Team Camo [ Sun Jul 29, 2012 12:08 pm ] |
Post subject: | Re: Help removing prop shaft |
Just the outdrive or the actual shaft from the outdrive? |
Author: | rob_E [ Sun Jul 29, 2012 12:11 pm ] |
The actual shaft from the out drive |
Author: | rob_E [ Sun Jul 29, 2012 12:41 pm ] |
Please describe just the outdrive |
Author: | Team Camo [ Sun Jul 29, 2012 12:46 pm ] |
Remove gear & snap ring, then front & real seals & bearings. Should be able to slide shaft out then. |
Author: | Bayoublackhunter [ Sun Jul 29, 2012 12:54 pm ] |
Author: | Team Camo [ Sun Jul 29, 2012 12:56 pm ] |
Haven't messed with any older than 2010, didn't know there was a difference tho. |
Author: | rob_E [ Sun Jul 29, 2012 4:40 pm ] |
on the rear there is somekind of spacer on the octagon or whatever shaped part that i cant get off and i got the front seal out but cant budge the bearing shaft is bent any one got some pointers |
