Thrust Loads https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=32290 |
Author: | sftull [ Tue Sep 11, 2012 12:59 pm ] |
Post subject: | Thrust Loads |
Can this type of bearing handle thrust loads? |
Author: | CLICKSTER [ Tue Sep 11, 2012 1:00 pm ] |
Post subject: | Re: Thrust Loads |
A vigina holds the best thrust load! just saying. |
Author: | Mag10 [ Tue Sep 11, 2012 3:56 pm ] |
They will hold up to the thrust loads your outdrive is seeing. I have always used single row ball bearings in my builds with no issues. Just make sure it has an appropriate rpm rating for what it will see in your application. Mag10 |
Author: | Quack Attacker89 [ Wed Sep 12, 2012 6:23 pm ] |
Lookin to change the bearing system in your home build? What was wrong with the tapered bearings you had before? Just curious cause I'm using the same taper bearings in my build. |
