david95
Joined: Thu Jan 12, 2012 5:15 pm Posts: 641 Location: Summerville, South Carolina
 Prop size for outboard?
Ima be using my Johnson 25 3 cyl for this duck season and was wondering what size prop would be good since ima be carrying a load and my prop now won't hardly get four people and decoys out the water! Thanks for any info.
_________________ 27 GDLT pushing a War Eagle 1542
Fri Sep 14, 2012 4:36 pm |
BayouBuster
Joined: Sat Jun 25, 2011 8:33 am Posts: 1352 Location: Genoa AR
 Re: Prop size for outboard?
It would help to know what size an pitch you have now.
Fri Sep 14, 2012 6:24 pm |
david95
It's a 10 1/2x 12 and pitch is 15.
Fri Sep 14, 2012 8:12 pm |
david95
What's a good jack plate to get?
Mon Oct 08, 2012 7:29 am |
CCC
Bobs is the best jack plate I've used
Mon Oct 08, 2012 10:06 am |
david95
Ima check em out I appriciate it!
Mon Oct 08, 2012 10:13 am |
Curltail
Joined: Tue Sep 06, 2011 1:25 pm Posts: 490 Location: Arkansas
Normally a 25 turns a 13" pitch best. You probably don't have a tach but I bet the 15 is not turning the engine but about 4800 rpm at best. The engine will not last long if you don't have the rpm up at WOT to at least 5200-5800 because the spark advance is at max and not enough rpm to back it up. This will cause detonation inside the cylinder. The 13" should be the golden egg for your set up.
Curl
_________________ 1752 Uncle J, Calen Stage 1 35 GTR
Fri Oct 19, 2012 7:15 am |
david95
Curltail, well thanks for the good information the motor does seem to be boggin down a little bit while WOT. Would it be Bette to get the 4 blade or 3 blade SS?
Fri Oct 19, 2012 7:26 am |
Curltail
I'd go with the 3 blade.
Mon Oct 22, 2012 7:35 am |
david95
Alright thank you.
Mon Oct 22, 2012 5:24 pm |
