It is currently Mon Jul 14, 2025 12:17 pm
[ 6 posts ] |
mud buddy drive shaft has a little wiggle
cwb012
if you pull on the prop the whole thing slides out about 1/8 in. The motor ran fine last weekend and as soon as we launched today it started to rattle. Could this be some bearing or something or does this sound like major problem?
Sat Oct 27, 2012 5:57 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
 Re: mud buddy drive shaft has a little wiggle
You sure it's not just the prop is loose?
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Sat Oct 27, 2012 6:06 pm |
cwb012
i did take prop off thinking i was going to get new one in mail before we went but didnt and had to put old one back on. The whole drive shaft slide out including the gear.
Sat Oct 27, 2012 7:39 pm |
cwb012
Is there anything besides the prop that would cause this?
Sat Oct 27, 2012 8:08 pm |
autogateman
Joined: Thu Sep 16, 2010 10:32 pm Posts: 4036 Location: Gonzales La
Yes. Remove lower unit, loosen Allen screws that hold gear on. With prop shaft end standing up on block of wood, tap pulley down onto shaft. Tighten Allen screws and you're done.
Sat Oct 27, 2012 8:57 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
Are there any groves worn in the shaft like around the seals? If its moving back and fourth check the shaft next to the seals just to make sure, check for any grease seeping out too, just some thoughts
Sat Oct 27, 2012 9:21 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 30 guests |
