It is currently Tue Jul 15, 2025 10:43 pm
Reply to topic  [ 10 posts ]
 Prop size for outboard?
Post Prop size for outboard?
Ima be using my Johnson 25 3 cyl for this duck season and was wondering what size prop would be good since ima be carrying a load and my prop now won't hardly get four people and decoys out the water! Thanks for any info.
27 GDLT pushing a War Eagle 1542
Fri Sep 14, 2012 4:36 pm
Post Re: Prop size for outboard?
It would help to know what size an pitch you have now.
Fri Sep 14, 2012 6:24 pm
It's a 10 1/2x 12 and pitch is 15.
Fri Sep 14, 2012 8:12 pm
What's a good jack plate to get?
Mon Oct 08, 2012 7:29 am
Bobs is the best jack plate I've used
Mon Oct 08, 2012 10:06 am
Ima check em out I appriciate it!
Mon Oct 08, 2012 10:13 am
Normally a 25 turns a 13" pitch best. You probably don't have a tach but I bet the 15 is not turning the engine but about 4800 rpm at best. The engine will not last long if you don't have the rpm up at WOT to at least 5200-5800 because the spark advance is at max and not enough rpm to back it up. This will cause detonation inside the cylinder. The 13" should be the golden egg for your set up.
Curl
1752 Uncle J, Calen Stage 1 35 GTR
Fri Oct 19, 2012 7:15 am
Curltail, well thanks for the good information the motor does seem to be boggin down a little bit while WOT. Would it be Bette to get the 4 blade or 3 blade SS?
Fri Oct 19, 2012 7:26 am
I'd go with the 3 blade.
Mon Oct 22, 2012 7:35 am
Alright thank you.
Mon Oct 22, 2012 5:24 pm
Users browsing this forum: No registered users and 37 guests
