It is currently Sun Jul 13, 2025 9:38 pm
[ 7 posts ] |
lcostley
 Rust on clutch
I was up in Manitoba duck hunting. For some reason my 27HP Kohler really struggled to get going. The motor is 2 years old. I took off the upper plastic housing that covers the clutch and belt and the clutch was rusty.
This was the first time that this has ever been removed.
Any suggestions as to what to do? I live in the St. Louis area, and there aren't any service dealers for MB here.
The belt looked good, but I am assuming that the clutch has issues engaging the belt.
Mon Nov 26, 2012 5:12 pm |
lcostley
 Re: Rust on clutch
Wow, not one suggestion?
I called Mud Buddy, left a message. No response...........Not happy.
Wed Dec 05, 2012 4:52 pm |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
 Re: Rust on clutch
Keep trying.
Wed Dec 05, 2012 5:49 pm |
Wildberry
Joined: Sun Apr 22, 2012 6:17 pm Posts: 1018 Location: DA HAVEN FL,
 Re: Rust on clutch
Your question will be answered in the order in which it was received
_________________ EMF 16x42, 3/16 skiff, 35 GTR Stage 0
Wed Dec 05, 2012 6:11 pm |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
 Re: Rust on clutch
Have you called BoatDr yet? 504-737-1203
Wed Dec 05, 2012 6:15 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
 Re: Rust on clutch
Good luck with CS from mud buddy, on another note rust being on your clutch most likely isn't the problem, to rule it out, turn key on do not start motor, flip clutch switch and see if you can turn it by hand, if you can turn the motor over then your good, your problem is else where.
What exactly was the mtoor doing, can you reach full RPMS? What does your Prop Measure from blade tip to blade tip?
Wed Dec 05, 2012 7:47 pm |
Buzz Killington
 Re: Rust on clutch
B. MacDonald
Wed Dec 05, 2012 8:35 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 42 guests |
