PD wobble in tower housing. ??? https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=35613 |
Author: | SCSuperfly [ Sat Dec 22, 2012 9:38 am ] |
Post subject: | PD wobble in tower housing. ??? |
I have some wobble in my tower housing on my 32 PD. Does anyone have any pics on how it's put together? Are there some common parts ( bushings) that I need to order before I take it apart? Had MB's before but this is my first PD. Don't know how it's put together. |
Author: | Will [ Sat Dec 22, 2012 10:08 am ] |
Post subject: | Re: PD wobble in tower housing. ??? |
Pump it full of grease |
Author: | T-Bubba [ Sat Dec 22, 2012 10:25 am ] |
if its bad get your tower bushings changed. the old ones have to be cut out and the new ones press in. dont let them get to bad bc they will wear out the top colar on your lower unit housing |
Author: | SCSuperfly [ Sat Dec 22, 2012 12:37 pm ] |
Bushing are shot. How much are they? |
Author: | naj [ Sat Dec 22, 2012 12:53 pm ] |
40 bucks each plus tax. |
Author: | SCSuperfly [ Sat Dec 22, 2012 1:04 pm ] |
does anyone have any pics or measurements of them? I'm a machinist and can probably make them before i could get them in the mail. Just wondering how big they are and stuff. I may have some material to turn some out. Thanks. |
Author: | naj [ Sat Dec 22, 2012 1:29 pm ] |
Author: | SCSuperfly [ Sat Dec 22, 2012 1:47 pm ] |
I understand that. I have some of that material. Also have some oil impregnated UHMW that would be bad a$$ as well. |
Author: | naj [ Sat Dec 22, 2012 3:14 pm ] |
I wish you would figure something better out. Problem with what PD installs in there is it only covers about 4 inches of the lower units upper neck. If it covered all of it the aluminum would wear out as bad which is what all of that slop / wobble is from. |
Author: | cb5331 [ Sat Dec 22, 2012 3:32 pm ] |
Wouldn't be hard to make them the entire length. Don't know if the uhmw will hold up as well but its a fuckload cheaper. I just had a buddy turn some bushings for another project out of that stuff and he said it is easy to turn. |
Author: | SCSuperfly [ Sat Dec 22, 2012 3:48 pm ] |
All that plastic turns easy. You have to make fixtures to get good tolerances because it will flex alot when thin. That's no problem either. Just have to get the measurements right. |
Author: | SCSuperfly [ Sat Dec 22, 2012 4:17 pm ] |
I can make almost anything But I have to wait till I take the thing apar't to see how its put together. |
Author: | SCSuperfly [ Thu Dec 27, 2012 6:05 pm ] |
Bushings ordered. Hope it's not too much of a PITA to get apart. |
Author: | Will [ Fri Dec 28, 2012 5:31 am ] |
Author: | SCSuperfly [ Fri Dec 28, 2012 12:25 pm ] |
Thanks for the pics. |
