It is currently Wed Jul 09, 2025 8:57 pm
Reply to topic  [ 11 posts ]
 Trim problem on gator trax
Post Trim problem on gator trax
I have a question guys,
On occasion my trim has quit working, but always started working again. Even when its not working, it's getting power...making a relatively loud clicking almost? Any thoughts on this
I believe the unit is a wearner?? It is an 07
Wed Apr 10, 2013 8:15 am
Post Re: Trim problem on gator trax
Are you asking about the trim on your motor? Assuming mud buddy?
If that is correct sounds like you have a corroded trim relay/circuit breaker and just needs replacing.
Sent from my MB865 using Tapatalk 2
Wed Apr 10, 2013 9:12 am
muddbuddy correct.
How can I replace/refurbish the relays? I am not very savy with that kind of thing...any help would be appreciated
Wed Apr 10, 2013 9:17 am
Look on back of starter. Should be 2 small circuit breakers with yellow plastic caps. You can buy a replacement from any parts house for about $5 that'll last you a couple months, or you can order new breaker from Boat Dr for about $20 that'll last you couple years.
Easy to replace. Just need 8mm socket, 10mm & 3/8 wrenches.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Apr 10, 2013 9:32 am
when you say a parts house, like a auto part place or a bosting store?
Wed Apr 10, 2013 9:54 am
Auto parts. It's a 20 amp breaker
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Apr 10, 2013 10:04 am
so all in all hopefully a pretty painless fix..anything else to know before I attempt ha
Wed Apr 10, 2013 10:29 am
I think the bottom breaker is the trim and the top the clutch. You should be able to tell the bad one (rusty or corroded).
Other than that do what Camo says and you should be good.
Wed Apr 10, 2013 11:05 am
thanks guys, I will try to do that this weekend.
Wed Apr 10, 2013 12:08 pm
I've had breakers from Napa on my motor for about 80 hours with no problems.
Wed Apr 10, 2013 12:38 pm
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Wed Apr 10, 2013 1:46 pm
Users browsing this forum: No registered users and 61 guests
