nautibynature
 pro drive lower unit update
What year did they switch to the new style?
_________________ 1844 DFOU CUSTOM, PRODRIVE 36 EFI
viewtopic.php?t=38177
Mon Apr 08, 2013 5:10 pm |
Kmoppert
Joined: Tue Jun 05, 2012 3:48 pm Posts: 2006 Location: Baton Rouge, LA
 Re: pro drive lower unit update
2008
_________________ "There's nothing a duck hunter hates more than another duck hunter" ----------------------------------------------------------------------------------------------------------------------------------------------- Custom 17x48 with a new Gen III Prodrive.
Mon Apr 08, 2013 5:53 pm |
Quackhead62
Joined: Fri Nov 30, 2012 7:47 pm Posts: 931 Location: Maurice,La
Kmoppert what's the word on ur PD did the boys at the shop tell u what caused u to shear off ur lower unit ?
_________________ Stage 2 36 HP Pro-Drive FPR W/ Bayou Boys Custom Skeg,Cave Plate,and Weed Cutter with MAC Exhaust Pushing a 17X54 Pro-Drive X-Series boat
Mon Apr 08, 2013 6:35 pm |
pooldoo73
Joined: Tue Jan 25, 2011 5:47 pm Posts: 886 Location: Plaquemine
Also did a lower unit upgrade in 08/2010.
_________________ 18'x54"CC Hanko/ 36PD
Wed Apr 10, 2013 7:53 am |
Kmoppert
Wed Apr 10, 2013 8:09 am |
OwenDickeson
I dont think it was just from wear and tear. I think something wasnt put together properly, or maybe they over torqued those bolts.
Wed Apr 10, 2013 5:25 pm |
shooter
What changes were made at that time? I've got a 2006 motor, should I consider updating the LU?
_________________ 32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
Fri Apr 12, 2013 12:29 pm |
Will
I upgraded to the newer greased lower and I'm not 100% sure this is the reason but mine slowed down exactly the same time. About 1mph top end, I know it sounds crazy, I don't know, could there be more resistance due to the grease versus oil?
Fri Apr 12, 2013 5:08 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
Possible. Ill swap you my old one for your new one so you can get that 1mph back.
_________________ 1850 & 36pd
Fri Apr 12, 2013 5:24 pm |
Will
Nope
Fri Apr 12, 2013 5:34 pm |
pooldoo73
When I add fresh grease to my LU, it always seems to b a little sluggish for the first hour r 2 of running, then picks back up after some of the grease gets slung out of there. At least it seems like that.
Wed Apr 17, 2013 6:27 pm |
