stubborn prop
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=40261
Author:  carl [ Wed May 01, 2013 6:35 pm ]
Post subject:  stubborn prop
how do i get stubborn prop off a 25hp mudd buddy bought the flat bar and 15" cresant but man that thing wont budge
Author:  msm8281 [ Wed May 01, 2013 6:37 pm ]
Post subject:  Re: stubborn prop
Why two different threads
Author:  GBB [ Mon May 06, 2013 7:57 am ]
Cut it off.
Author:  cupped up [ Fri May 10, 2013 5:36 pm ]
Get a big 1/2" drive socket and cut it to fit over the hub and grab the blade and use an impact to get that bitch off.
Author:  SCSuperfly [ Sat May 11, 2013 3:21 pm ]
Which MB? Sure it's not a hex?
Author:  fireman1293 [ Sat May 11, 2013 6:47 pm ]
Here's a thought. Thread on a nut behind your prop, weld it to the prop. Soak the living crap out of it with PB blaster or equivalent. Then take an impact socket to the nut and try to spin it off. That way if it breaks loose you can cut off the nut and reuse the prop. Good luck
Author:  instagator911 [ Sun May 12, 2013 12:27 am ]
heat the prop hub with out heating the shaft. move prop till it starts 2 grab again then reheat prop. if shaft gets hot, stop and let cool. repeat till prop comes off.
