It is currently Sat Jul 12, 2025 11:09 pm
Reply to topic  [ 3 posts ]
 Replacing shaft seal nut on a PD
Post Replacing shaft seal nut on a PD
Do I engage the clutch to take the prop and seal nut off of the shaft? I've heard people doing that but also saw in the PD pdf file not to engage the clutch to loosen the prop... How should I break the prop loose???
Wed May 08, 2013 8:29 pm
Post Re: Replacing shaft seal nut on a PD
Put a wratchwd extension in the hole in the clutch to keep the prop from moving. Take a 6ft 2x4 and drill a hole in it (1"-1.5"...big enough to slide it on the shaft against the prop) about a ft from one end and break that bitch loose. Prop will bite the wood and youre good to go. Neversieze the shaft when ya put it back together.
1850 & 36pd
Wed May 08, 2013 8:40 pm
Thanks man!
Wed May 08, 2013 9:02 pm
Users browsing this forum: No registered users and 21 guests
