im replacing trim unit on mudbuddy
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=40736
Author:  bigjohn33 [ Tue May 14, 2013 8:08 am ]
Post subject:  im replacing trim unit on mudbuddy
Hey fellers, IT has gotten to the point where I must replace my old bear trim unit (surprised it lasted this long) a 2006 mudbuddy 29hp.
My question is should I go with the Thompson unit that is a couple hundred dollars
or try and upgrade to the mercury 800$
I only put 15-20 hours on the boat a year so I want to take that into consideration.
Also can the Thompson trim be put on without pulling the motor off?
Thanks
Author:  Z71v2.0 [ Tue May 14, 2013 8:10 am ]
Post subject:  Re: im replacing trim unit on mudbuddy
Get the merc. Why spend a couple hundred? Spend the rest for the merc and be done with it
Author:  SCmudder7071 [ Tue May 14, 2013 8:37 am ]
To change to the Thompson all you have to do is change the slides. I finally swapped to the Merc after going through 4 Thompson's within a year. They were all under warranty thank goodness. The Merc is where it's at.
Author:  tinman454 [ Tue May 14, 2013 8:47 am ]
From what I here you are much better off putting on a merc trim. Are you planning on keeping the motor for a few years? If not just put a Thompson back on. I you are planning on keeping the motor bite the bullet now and go with a merc trim.
Author:  bigjohn33 [ Tue May 14, 2013 2:11 pm ]
Are changing out the slides difficult?
Author:  SCmudder7071 [ Tue May 14, 2013 3:32 pm ]
4 bolts. That's it.
