PD prop ?
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=43909
Author:  tsbroscoe [ Tue Aug 06, 2013 8:41 pm ]
Post subject:  PD prop ?
Ok guys I installed a new prop here a while back due to my old was worn down below 11 1/2". I put a stock pd prop on my stock pd 36. With the new prop I'm not running any faster and my rpm's dropped to 3600 wide ass open in water. I am only running about 23 with 2 people and medium size load... When I am at an idle I'm at 1200 RPMs ...why am I at such low RPMs at full speed?
Author:  OwenDickeson [ Tue Aug 06, 2013 8:45 pm ]
Post subject:  Re: PD prop ?
what are your full throttle rpms in neutral?
Author:  pooldoo73 [ Wed Aug 07, 2013 7:57 am ]
Could b that the valves are leaking much worse now, u just didn't notice the loss n power due to the worn prop allowing u to turn more revs. Just went through this very same thing.
Author:  Will [ Wed Aug 07, 2013 8:31 am ]
Check the governor screw and make sure it didn't creep down on you.
Author:  tsbroscoe [ Wed Aug 07, 2013 11:50 am ]
Wide open out of water is 4200-4300
Before the new prop I was running 4000 or so with the old prop
Author:  Will [ Wed Aug 07, 2013 11:54 am ]
Make sure your carb is opening all the way. Might not be getting true full throttle.
