GTR35 Grass Cutter https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=44123 |
Page 1 of 2 |
Author: | MNGunner [ Mon Aug 12, 2013 9:22 am ] |
Post subject: | GTR35 Grass Cutter |
http://www.youtube.com/watch?v=3f1yGz5KRqk At 37 sec Fred Zink shows a "grass cutter" on his Go-Devil. Anyone try something like this for a GTR35?? I ran in wild rice and that stuff just wraps in the gap between the prop and the rear seal. Reversing doesn't help. |
Author: | barnes_53 [ Mon Aug 12, 2013 9:34 am ] |
Post subject: | Re: GTR35 Grass Cutter |
grass cutter? I still seen grass wrapped around the bushing right in front of the prop. That's the stuff that can burn up seals and bushings. |
Author: | MNGunner [ Mon Aug 12, 2013 9:45 am ] |
Author: | pooldoo73 [ Mon Aug 12, 2013 9:47 am ] |
Bayouboy makes a nice one for the PD, works very well. I'm sure someone could come up wif one for a GT. |
Author: | Bigrich [ Mon Aug 12, 2013 9:47 am ] |
Author: | Will [ Mon Aug 12, 2013 9:54 am ] |
According to DDM grass don't bother a GTR... |
Author: | deltaduckmaster [ Mon Aug 12, 2013 9:57 am ] |
Author: | RootSumn [ Mon Aug 12, 2013 9:59 am ] |
I have one on mine and like said grass just gets wrapped in the gap. I haven't tried it yet without it. |
Author: | deltaduckmaster [ Mon Aug 12, 2013 10:00 am ] |
I think all the sd have this problem. |
Author: | Will [ Mon Aug 12, 2013 10:21 am ] |
Author: | med [ Mon Aug 12, 2013 10:28 am ] |
Same here Will. That little device takes care of the weeds nicely |
Author: | MNGunner [ Mon Aug 12, 2013 11:22 am ] |
Author: | cb5331 [ Mon Aug 12, 2013 11:24 am ] |
Boatdr had one for the MB's. Don't know if it would work on a GT or not. |
Author: | MNGunner [ Mon Aug 12, 2013 11:35 am ] |
Author: | cb5331 [ Mon Aug 12, 2013 12:04 pm ] |
Andy has been busy, busy. Might want to give him a call if you'd like an answer sometime soon. |
Author: | MNGunner [ Mon Aug 12, 2013 2:43 pm ] |
Author: | BlueShamu [ Mon Aug 12, 2013 5:04 pm ] |
viewtopic.php?f=3&t=40383&hilit=grass+cutter Scroll down to near the bottom of the page to see Bayouboy's grass cutter. Sweet idea if'n it's working. I think I need to send him a PM! |
Author: | JIMMY W [ Mon Aug 12, 2013 5:08 pm ] |
You don't need that shit on a GatorTail ![]() ![]() |
Author: | MNGunner [ Mon Aug 12, 2013 6:07 pm ] |
Author: | Dan R [ Mon Aug 12, 2013 6:34 pm ] |
Mn. Keep me posted on this as well. Most of what I hunt is in the rice so I'd like to get ahead of the problem if possible. Like I said, should be here in two weeks. |
Author: | Dan R [ Mon Aug 12, 2013 7:40 pm ] |
It almost looks like the cutter on Fred Zink's motor would fit on the brace above the shaft on the GTR. Thoughts? |
Author: | Will [ Tue Aug 13, 2013 4:33 am ] |
Author: | Will [ Tue Aug 13, 2013 4:35 am ] |
ImageUploadedByTapatalk1376390073.196950.jpg ImageUploadedByTapatalk1376390096.735452.jpg ImageUploadedByTapatalk1376390121.636379.jpg |
Author: | MNGunner [ Tue Aug 13, 2013 6:52 am ] |
Author: | MNGunner [ Tue Aug 13, 2013 6:53 am ] |
Author: | Will [ Tue Aug 13, 2013 6:59 am ] |
SS, don't think aluminum would last long. as far as cost, you'll need to ask bayouboy, its his baby...sorry but I wont post what I paid incase he has changed price or something... |
Author: | Quackhead62 [ Tue Aug 13, 2013 7:04 am ] |
im with Will on this one. I recently got bayou boys custom skeg, cavi plate, and weed cutter it is well worth it. It makes a big diffrence in the thick vegies. You just have to send bayou boy your cavi plate so he can make the mod. It is all well worth it |
Author: | Will [ Tue Aug 13, 2013 7:06 am ] |
Cut mine with a hole saw and a sawzall, then hit it with a flap disk. Took 10 minutes tops. |
Author: | Quackhead62 [ Tue Aug 13, 2013 7:08 am ] |
yea it's not a hard mod to do yourself. It sure helps out a lot though |
Author: | MNGunner [ Tue Aug 13, 2013 7:11 am ] |
Author: | cupped up [ Wed Aug 14, 2013 6:26 am ] |
There's already a tab on the GT skeg that ends up very close to the prop...and if you look at the hub of the prop on the inward facing side of the prop, it's not round, the hub goes out to start the blades...and that area of the prop is the same diameter as the little tab on the skeg... Anyways, I bet if you could get just the cutter from BB or get something similar machined and bolt it onto that tab it would work really well cutting weeds from around the shaft. As long as the tab is straight it serves the same purpose, I've noticed that mine bends sometimes and I have more issues with wrapping grass but once I straighten it out its fine...but if you want improved weedless ability, a cutter on that tab would probly work well. |
Author: | MNGunner [ Wed Aug 14, 2013 8:55 am ] |
Author: | cupped up [ Wed Aug 14, 2013 9:05 am ] |
Doesn't look like it, must be just the newer style skeg with the cut out torque tab on it |
Author: | cupped up [ Wed Aug 14, 2013 9:08 am ] |
Like this |
Author: | MNGunner [ Wed Aug 14, 2013 9:21 am ] |
Author: | cupped up [ Wed Aug 14, 2013 9:29 am ] |
Idk, I've never seen one with the rock guard in person. I know the older skegs didn't have the torque tab, maybe it was a new addition once they started cutting the torque tab in? I see the top of your skeg is bent some, the further it is away from the prop the more grass issues you will have. |
Author: | MNGunner [ Wed Aug 14, 2013 10:06 am ] |
Author: | Bigrich [ Wed Aug 14, 2013 10:17 am ] |
The 27" drive and 32" drive skeg's are built different for torque tab On 32" skeg torque tab is solid on 27" it has where u can bend the skeg in the middle And they don't make a rock skeg for a 32" drive |
Author: | JIMMY W [ Wed Aug 14, 2013 11:38 am ] |
Don't know about all that bullshit! |
Page 1 of 2 | All times are UTC - 6 hours |
