It is currently Fri Jul 11, 2025 8:04 pm
Reply to topic  [ 12 posts ]
 Gdsd 3blade2blade?
Post Gdsd 3blade2blade?
I have a 23 hp gdsd it has the three blade but seems like that lil motor struggles to turn it when in a bind. Would a 2 blade be better? And what about cutting of the cavatation plate?
16x38 godae hull 40hp merc for now
Wed Sep 18, 2013 1:16 pm
Post Re: Gdsd 3blade2blade?
viewtopic.php?f=3&t=43812&hilit=go+devil+2+blade
35 GTR chasin a BBC 1848
Wed Sep 18, 2013 4:34 pm
Jusr swapped from 2 blade to 3 blade and changed reduction less rpms one person same speed carring capacity way better i just bought heads cam and exh if i can get my rpms back up it wwill do way btr hope i get enough power to run the 2 blade reduction with the 3 blade prop
1440 xpress 23 gdsd... Sold
1644 gd 35 gtr
Fri Sep 20, 2013 8:12 am
U will not be happy with the two blade my has way more launch with the three blade
1644 gd 35 gtr
Fri Sep 20, 2013 8:14 am
Just put on a new three blade this weekend ...you can go wrong with one.
Tue Oct 08, 2013 7:18 pm
Tue Oct 08, 2013 7:20 pm
Tue Oct 08, 2013 8:22 pm
So the thread is unclear. Just for clarification, is the design intention of the 3 blade prop supposed to increase low end torque (load carrying capacity)? And the 2 blade prop high end (max speed on a light load)? What is the overall effect on RPM's?
Wed Jan 29, 2014 9:53 pm
2 blade is better in mud and grass
Sent from my iPhone using
Wed Jan 29, 2014 9:57 pm
Wed Jan 29, 2014 10:13 pm
Yes the 3 blade does work great in open deep water and pushes a load better but it was originated to prevent the motor from having vibration since the vibration is caused from a 2 blade prop slapping the waters surface
Wed Jan 29, 2014 10:16 pm
I love how my motor feels with the three blade. If you work the trim tabs you can get it high up on the water and that will help you in the muck. The two blade is much better in grass and mud, however the overall performance is better with the three blade. Less vibration and a better handling.
40HP Gatortail
Thu Jan 30, 2014 1:02 am
Users browsing this forum: No registered users and 57 guests
