Gdsd 3blade2blade? https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=45583 |
Author: | Greentopkilla23 [ Wed Sep 18, 2013 1:16 pm ] |
Post subject: | Gdsd 3blade2blade? |
I have a 23 hp gdsd it has the three blade but seems like that lil motor struggles to turn it when in a bind. Would a 2 blade be better? And what about cutting of the cavatation plate? |
Author: | fowllife08 [ Wed Sep 18, 2013 4:34 pm ] |
Post subject: | Re: Gdsd 3blade2blade? |
viewtopic.php?f=3&t=43812&hilit=go+devil+2+blade |
Author: | genson [ Fri Sep 20, 2013 8:12 am ] |
Jusr swapped from 2 blade to 3 blade and changed reduction less rpms one person same speed carring capacity way better i just bought heads cam and exh if i can get my rpms back up it wwill do way btr hope i get enough power to run the 2 blade reduction with the 3 blade prop |
Author: | genson [ Fri Sep 20, 2013 8:14 am ] |
U will not be happy with the two blade my has way more launch with the three blade |
Author: | Duck Hunt Guy [ Tue Oct 08, 2013 7:18 pm ] |
Just put on a new three blade this weekend ...you can go wrong with one. |
Author: | North LA Hunter [ Tue Oct 08, 2013 7:20 pm ] |
Author: | Duck Hunt Guy [ Tue Oct 08, 2013 8:22 pm ] |
Author: | The Hairy Coot [ Wed Jan 29, 2014 9:53 pm ] |
So the thread is unclear. Just for clarification, is the design intention of the 3 blade prop supposed to increase low end torque (load carrying capacity)? And the 2 blade prop high end (max speed on a light load)? What is the overall effect on RPM's? Sent from my iPad using Tapatalk HD |
Author: | AKA Freshwaterkilla [ Wed Jan 29, 2014 9:57 pm ] |
2 blade is better in mud and grass Sent from my iPhone using |
Author: | The Hairy Coot [ Wed Jan 29, 2014 10:13 pm ] |
Author: | AKA Freshwaterkilla [ Wed Jan 29, 2014 10:16 pm ] |
Yes the 3 blade does work great in open deep water and pushes a load better but it was originated to prevent the motor from having vibration since the vibration is caused from a 2 blade prop slapping the waters surface Sent from my iPhone using |
Author: | WhoDat88 [ Thu Jan 30, 2014 1:02 am ] |
I love how my motor feels with the three blade. If you work the trim tabs you can get it high up on the water and that will help you in the muck. The two blade is much better in grass and mud, however the overall performance is better with the three blade. Less vibration and a better handling. |
