It is currently Mon Jul 07, 2025 10:04 pm
Reply to topic  [ 28 posts ]
 GTR trim problems too often
Post GTR trim problems too often
My trim has given me some trouble since day one.
Well now it will run the trim up but nothing down 5 amp fuse is good and the breaker isn't tripped??? Anybody?
Sent from my XT907 using Tapatalk 2
Sat Oct 19, 2013 12:36 pm
Post Re: GTR trim problems too often
You bypass the switch to rule it out?
Sat Oct 19, 2013 1:07 pm
Relays maybe.
35 GTR on Uncle J 18/54
Sat Oct 19, 2013 1:15 pm
Is it old style trim unit or new style? My old style the brushes went bad. So I put new style on it had no problems.
GTB 18/46 Extreme. GTR 35 cam,heads,mm
Sat Oct 19, 2013 1:31 pm
I had the old set up with the relays and it always gave me problems. I installed the box on the tiller handle that does away with the relays and haven't had a problem since.
Are you running a console or tiller handle?
Sat Oct 19, 2013 1:40 pm
I've had troubles keeping oil in mine.... Waiting to upgrade to newer unit and wash my hands of this gen 1 trim piece of shit.
Sat Oct 19, 2013 2:32 pm
Jus got mine back had to replace my trim unit bc it was leaking. Only had 15hrs on it. Gator tail took care of it no problem
1852 Dfou custom 35gtr
Sat Oct 19, 2013 3:24 pm
If it has relays.....shake them and the wires around a lil bit .
Get somebody to hold the switch down when it isn't workin and wiggle each wire near the relays one at a time to find culprit.
Sat Oct 19, 2013 4:22 pm
Make sure there are no broken wires, I had one break on the box above the starter and it did the same thing.
Sent from my iPhone using Tapatalk -
Sat Oct 19, 2013 5:51 pm
Yeah tried it all guys no luck...the relays are engaging or at least making noise when I try and trim down but no action. Could it be over pressured because it was ran on the up position too long?
Sat Oct 19, 2013 8:51 pm
swap the relays and see what happens. You can have one bad relay and it will still click but not go in one direction. If it is the relays look into the forward/ reverse solenoids and get rid of those relays.
Uncle J's Custom Bow Fishing Rig 20/72 30" Sides, Calens Modded Dual GTR's
Boat Name: The Gar Barge
Team Name: Southern Stickers
18/58 Uncle J Custom 3/16 bottom 24" sides w/catwalks 6' front deck with another GTR Pushing it.
17/54 Gator Trax 35 Mud Buddy W/All aluminum FPR Mod SOLD
Sat Oct 19, 2013 9:10 pm
:o
Tick Tock --- season is approaching fast....
Sat Oct 19, 2013 10:11 pm
Lots of flocks of Wildfowl moving south along the Outer Banks/Atlantic Flyway now...
Check out "Joe Guide hunting videos" on YOUTUBE...
Sun Oct 20, 2013 4:03 am
Sounds like a relay.
Sun Oct 20, 2013 5:57 pm
Ordering 2 tomorrow.. thanks
Mon Oct 21, 2013 6:38 pm
HOTSAUCE170 wrote:
Mon Oct 21, 2013 6:48 pm
Mon Oct 21, 2013 7:01 pm
16X48 WELDBILT -25GTR EFI-sold
18x48 GTB - 35 GTR
Crown royal pro-staff
Mon Oct 21, 2013 7:18 pm
Tue Oct 22, 2013 6:03 am
Haven't actually ordered yet....why?
Tue Oct 22, 2013 10:26 am
Tue Oct 22, 2013 10:40 am
Tue Oct 22, 2013 11:05 am
Pull the relays apart and grease the contacts with dielectric grease; then seal them together with silicon.
Tue Oct 22, 2013 11:15 am
Tue Oct 22, 2013 11:48 am
Tue Oct 22, 2013 12:06 pm
go to the solenoid set up. Seems like it was will that did the wright up on it a while back
Tue Oct 22, 2013 1:04 pm
viewtopic.php?f=3&t=46011
Tue Oct 22, 2013 2:07 pm
Users browsing this forum: No registered users and 38 guests
