mudbuddy prop wear causes weird clanking.
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=46736
Author:  goodbuddy13 [ Thu Oct 24, 2013 11:37 pm ]
Post subject:  mudbuddy prop wear causes weird clanking.
my mudbuddy is making a bad racket in the bottom shaft area. the prop is seriously wore, and some friends and i think that may be causing an unbalance. wich is causing the noise. no play in the prop at all.
Author:  eljefe [ Fri Oct 25, 2013 6:06 am ]
Post subject:  Re: mudbuddy prop wear causes weird clanking.
What does the prop measure out at and you are probably right..... but look for a crack in the shaft housing about 10" from prop.
sent from the former Republic of Texas.
Author:  goodbuddy13 [ Fri Oct 25, 2013 8:44 am ]
its a 9/6 prop but i havnt measured it at wore out size. theres no cracks on the housing
Author:  Prodigy [ Fri Oct 25, 2013 8:55 am ]
If the prop is causing a vibration u need to get another one bro and get it off that motor.
Author:  wtyner86 [ Fri Oct 25, 2013 9:02 am ]
check your bearings, a worn out bearing will let the shaft rattle around.
Author:  T10 [ Thu Oct 31, 2013 12:51 pm ]
Author:  SCSuperfly [ Tue Nov 05, 2013 5:58 am ]
If the prop is that bad then it probably trashed the bearings. You'll need to replace them fast before it does more damage.
Author:  banded-mallard [ Tue Nov 05, 2013 6:19 am ]
I would have to think that excessive prop wear would do nothing other than increase rpm's, less resistance. If you run sandy hard bottoms, it sould wear even. So if it is indeed work, you should see nothing. If you hit something and 1 blade is worn more than the other, you should see excessive vibration due to the prop not being balanced anymore. The clanking sound has nothing to o with prop wear and is bearing related. Now, if you have excessive vibration in the handle, then check the prop.
