Squeaking problem https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=48821 |
Author: | buckshotgp89 [ Fri Jan 03, 2014 2:42 pm ] |
Post subject: | Squeaking problem |
I have an 08 35gtr. When i put it in gear in the water its making a squeaking noise loud and gets worse the more throttle i give. When it is out of the water on the trailer and i put it in gear it makes no noise whatsoever. So my question is what is causing this? Any ideas or if anyone has a clue it would help tremendously. Im scared to run it anymore. |
Author: | msm8281 [ Fri Jan 03, 2014 2:49 pm ] |
Post subject: | Re: Squeaking problem |
Check brake pads. Could be pad rubbing on rotar. |
Author: | buckshotgp89 [ Fri Jan 03, 2014 2:53 pm ] |
Hmm ok i will check that. You dont think it would squeak out of the water too though? |
Author: | msm8281 [ Fri Jan 03, 2014 2:56 pm ] |
The added vibration created by the prop being in water could cause it. IDK take the clutch cover off and check it. |
Author: | buckshotgp89 [ Fri Jan 03, 2014 3:04 pm ] |
Will try that. Should i take the caliper off and run it in the water to know if thats the problem? |
Author: | msm8281 [ Fri Jan 03, 2014 3:05 pm ] |
No just look at it and see if its touching |
Author: | buckshotgp89 [ Fri Jan 03, 2014 3:11 pm ] |
Its not suppose to be touching at all? Cause if its like any other brake system ive messed with the pads are still pretty much touching even when u let off the brake. |
Author: | Will [ Fri Jan 03, 2014 3:15 pm ] |
Check your intake gaskets for leaks... |
Author: | buckshotgp89 [ Fri Jan 03, 2014 3:21 pm ] |
What intake gaskets...where at |
Author: | Will [ Fri Jan 03, 2014 3:35 pm ] |
You're gonna have to take the cowling off to get to them. Can you take the spark plugs out and see what they look like, if you have a black one and then one that's creamy color, that side is leaking indicating a lean mixture with the intake sucking in air. Sometimes the intake will leak and the gasket will act like a reed as whistle, getting worse the morse gas you give it while the boat is under a load. I'm not saying that's your issue but it's something to check. |
Author: | buckshotgp89 [ Fri Jan 03, 2014 3:55 pm ] |
Ok thanks. I will check plugs. But it doesnt sound like an air whistle its more metallic like a bearing or something. Im not familiar with where any bearings are or any of the drive components really. |
Author: | Will [ Fri Jan 03, 2014 4:05 pm ] |
Maybe some others will chime in, I had one throw me for a loop, sounded just like a squeaking belt and got louder, thought the fan was rubbing the shroud and turned out to be an intake leak where the intake meets the head. Good luck |
Author: | buckshotgp89 [ Fri Jan 03, 2014 4:15 pm ] |
Thanks |
Author: | buckshotgp89 [ Sun Jan 05, 2014 8:44 am ] |
Anybody have any other ideas?? |
Author: | TDUET [ Sat Jan 11, 2014 7:40 pm ] |
belt rubbing on the back of the frame! check that also |
