It is currently Mon Jul 07, 2025 12:58 am
Reply to topic  [ 32 posts ]
 Am I missing something here? ? MB people - where you at?
Post Am I missing something here? ? MB people - where you at?
Winterizing a buds Mud buddy and went to grease the lower unit and...
What the hell?? Wheres the zerk? !
2008? I'm guessing? ??
The overflow nut is there but how the heck do I refill this thing?
Brandon M.
KCCO
B. MacDonald
Sat Feb 01, 2014 12:37 pm
Post Re: Am I missing something here? ? MB people - where you at?
Oops lol....
Sent from my iPad using Tapatalk -
Sat Feb 01, 2014 12:41 pm
Sat Feb 01, 2014 1:48 pm
Moral of the story? Dont buy a mudbuddy! :lol:
Sat Feb 01, 2014 1:52 pm
so do I just drill and tap a zerk ?
and then do i call MB and refer to them as a bunch of motards? lol
B. MacDonald
Sat Feb 01, 2014 2:05 pm
maybe before i drill into anything i'll get him to call MB and ask what the hell is up....
B. MacDonald
Sat Feb 01, 2014 2:06 pm
Maybe it don't need any grease :?:
Gator tail
Sat Feb 01, 2014 2:13 pm
I'd call the boatdr and bother him! :lol:
You could probably pm prodigy also. I bet he'd help you out.
this is unreal!
I feel like this is something rather important to have on the lower unit
how could you miss this during the install?
B. MacDonald
Sat Feb 01, 2014 2:31 pm
They said they was gonna revolutionize, maybe this it... :!:
Gator tail
Sat Feb 01, 2014 3:09 pm
Pm'd prodigy and will call boatDR on monday
Changed the oil, checked belt tension, fogged it etc...
Not touching that lower unit until I get hold of either MB or the boat DR
B. MacDonald
Sat Feb 01, 2014 3:45 pm
I would say that drive needs a lot more than grease if it's 6 yr's old and never been grease. :shock: look on the bright side it should have fallen apart by now! :)
08 35 mudbuddy, gator traxx 3 man hide.
Sat Feb 01, 2014 4:09 pm
B. MacDonald
Sat Feb 01, 2014 4:28 pm
Motor and lower unit are spotless
B. MacDonald
Well the drive is good for 50 hrs before it needs to be grease . So every thing should be good how did it look in the bottom of the belt cover? I would say your only choice is to put a zerk fitting in your self. I'am not shure if you can do it with out taking every thing out of the drive tube? Did you take the screw out to see if they put any grease in there? If there is how did they do it?? Also on mine there are some other zerk fittings on the motor where it mounts on the boat are these there?
Sat Feb 01, 2014 7:08 pm
Fork that^^^^I would make MB cover all under warranty!!! I would not be doing that. they should send you a whole new shaft and outdrive.
Sat Feb 01, 2014 7:21 pm
B. MacDonald
Sat Feb 01, 2014 8:41 pm
I gotta buddy that has an old old hyperdrive an his doest have one either but it has one in side the housing you have to pull the prop an shit off to get to it
4500 black death with a little more in it strapped to a 1848 wc custom
Sat Feb 01, 2014 9:01 pm
B. MacDonald
Sat Feb 01, 2014 9:15 pm
Through the power of the Internet
Think on mb website they have the process under hyper service updates
Its a threaded grease fitting
4-6 pumps is supposed to do for 200hrs?? Wtf??
B. MacDonald
Sat Feb 01, 2014 9:47 pm
Sry 8 -10 pumps....
B. MacDonald
Sat Feb 01, 2014 9:49 pm
B. MacDonald
Sat Feb 01, 2014 10:04 pm
Once a year is about right. What's the issue?
Sat Feb 01, 2014 10:14 pm
Mine is just like that. Take the prop off and the bearing seal at the prop end. Take that little bolt out and replace with zerk... if u just pump with grease it will blow a seal out. Don't ask me how I know.
Sat Feb 01, 2014 10:50 pm
B. MacDonald
Sun Feb 02, 2014 6:03 am
That's in believable !! MB never fails to keep failing ! Lol
Sun Feb 02, 2014 7:58 am
Buzz does it have zerk fittings on the motor mounts ? Mine has two up there that need grese also one other thing I have done to it is open up the football and put die electric grese on the wire connections on the switch contacts. Water gets in there and freezes. It's prone to corroding inside of there. I also think the salt on the roads helps a lot?
Sun Feb 02, 2014 9:15 am
^ Always take the allen head screw out. I pump grease til it gets clean.
Sun Feb 02, 2014 10:16 am
B. MacDonald
Sun Feb 02, 2014 11:54 am
Sun Feb 02, 2014 1:22 pm
correct........u have to back out that one screw and put a zirk fitting on and fill that way............ carefully
the design was changes several years ago.............
Prodigy Boats
https://www.facebook.com/Prodigyboats
www.prodigyboats.com
Contact for info - http://prodigyboats.com/contact-us/
706-253-7766
Mon Feb 03, 2014 11:37 pm
B. MacDonald
Tue Feb 04, 2014 4:45 am
Users browsing this forum: No registered users and 34 guests
