It is currently Mon Jul 07, 2025 4:06 am
Reply to topic  [ 26 posts ]
 Lower Unit Spun On It's Own
Post Lower Unit Spun On It's Own
I have a 2013 PD 36HP. I went take a ride yesterday and when I was coming back in to the landing the lower unit turned on me and made the boat turn hard to the left. The thing is that I didn't ratchet to reverse at all. Not sure what could have caused it but maybe the last time I used it I didn't lock the pin in all the way. Any body know what could of caused this besides the pin not being locked in?
17x48 xseries 36hp Pro-Drive
Tue Jan 21, 2014 6:32 am
Post Re: Lower Unit Spun On It's Own
Tue Jan 21, 2014 6:36 am
Tue Jan 21, 2014 7:13 am
The "hard left" is throwing me off. The LU naturally spins the other way that would make the boat turn right, right?
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Tue Jan 21, 2014 7:24 am
I would take the pin off and check it out before using again.
Tue Jan 21, 2014 8:09 am
Tue Jan 21, 2014 8:46 am
Tue Jan 21, 2014 9:06 am
My buddy was in front of me and he thought I had lost my hat because it turned so fast lol. I'll pull the pin off and see if the spring is broke or what not
Tue Jan 21, 2014 9:12 am
I lost the main bolt in the hydraulic reverse one day hauling ass through a canal and hit the marsh bank, didn't know wtf happened for a second. Went back with a grade 8 and double jamb nutted that bustard :lol:
Tue Jan 21, 2014 9:53 am
16x42 Charles Leonard ... Sold
18x46 Gator Tail w/ 35 gtr stage 1 by hoyt
Tue Jan 21, 2014 11:15 am
Tue Jan 21, 2014 11:19 am
Tue Jan 21, 2014 11:24 am
Tue Jan 21, 2014 1:56 pm
What you encountered is known as the death spin. Your pull pin can be over greased and its getting hydrolocked which isn't allowing it to return fully. Work it by hand and force any excess grease out ( up and down). I personally never grease my pin, I just pull it down and spray it with a lubricant. Other issues could be a worn or bent pin. In those cases you will need a new one and that should fix the problem. In the rare occurrence it doesn't, than you will have to replace the reverse plate as well.
The reason it went left was do to prop rotation / tiller torque.
Wed Jan 22, 2014 10:26 am
He's alive!!! Holy chit!
Wed Jan 22, 2014 10:37 am
I feel like the walking dead! lol
Wed Jan 22, 2014 10:42 am
Thanks for the help guys. I'm gonna work on it today.
Wed Jan 22, 2014 11:12 am
It would be a good idea to remove the pin and inspect it visually, It also could have a weak or broken return spring.
Wed Jan 22, 2014 12:55 pm
Wed Jan 22, 2014 3:13 pm
Well I got to look at the pin and look deeper in to it and found that there was a little more grease then it should have. I just took a rag and cleaned around it and what not and put new grease in it. No problems so far. Thanks for the help guys
Mon Jan 27, 2014 6:10 am
I bet it will be months before your asshole is not puckered driving that thing around.
Always gonna be on your mind.
Mon Jan 27, 2014 7:16 am
did they change something between 08 and 13. i know that it is a lot of time but i am 99% sure that my lu on my PD spins to the clockwise which if this happened to me would put me in a left turn. just wondering?
Mon Jan 27, 2014 4:03 pm
32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
Mon Feb 03, 2014 2:55 pm
Wed Feb 05, 2014 5:26 am
:lol: I will use that one, soon!
Sent using Morse Code from my not so smart phone.
Wed Feb 05, 2014 12:34 pm
Users browsing this forum: No registered users and 43 guests
