Am I missing something here? ? MB people - where you at?
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=49860
Author:  Buzz Killington [ Sat Feb 01, 2014 12:37 pm ]
Post subject:  Am I missing something here? ? MB people - where you at?
Winterizing a buds Mud buddy and went to grease the lower unit and...
What the hell?? Wheres the zerk? !
2008? I'm guessing? ??
The overflow nut is there but how the heck do I refill this thing?
Brandon M.
KCCO
Author:  Mayhem73 [ Sat Feb 01, 2014 12:41 pm ]
Post subject:  Re: Am I missing something here? ? MB people - where you at?
Oops lol....
Sent from my iPad using Tapatalk -
Author:  MNGunner [ Sat Feb 01, 2014 1:48 pm ]
Author:  cb5331 [ Sat Feb 01, 2014 1:52 pm ]
Moral of the story? Dont buy a mudbuddy! :lol:
Author:  Buzz Killington [ Sat Feb 01, 2014 2:05 pm ]
so do I just drill and tap a zerk ?
and then do i call MB and refer to them as a bunch of motards? lol
Author:  Buzz Killington [ Sat Feb 01, 2014 2:06 pm ]
maybe before i drill into anything i'll get him to call MB and ask what the hell is up....
Author:  Old School [ Sat Feb 01, 2014 2:13 pm ]
Maybe it don't need any grease :?:
Author:  cb5331 [ Sat Feb 01, 2014 2:13 pm ]
I'd call the boatdr and bother him! :lol:
You could probably pm prodigy also. I bet he'd help you out.
Author:  Buzz Killington [ Sat Feb 01, 2014 2:31 pm ]
this is unreal!
I feel like this is something rather important to have on the lower unit
how could you miss this during the install?
Author:  Old School [ Sat Feb 01, 2014 3:09 pm ]
They said they was gonna revolutionize, maybe this it... :!:
Author:  Buzz Killington [ Sat Feb 01, 2014 3:45 pm ]
Pm'd prodigy and will call boatDR on monday
Changed the oil, checked belt tension, fogged it etc...
Not touching that lower unit until I get hold of either MB or the boat DR
Author:  tinman454 [ Sat Feb 01, 2014 4:09 pm ]
I would say that drive needs a lot more than grease if it's 6 yr's old and never been grease. :shock: look on the bright side it should have fallen apart by now! :)
Author:  Buzz Killington [ Sat Feb 01, 2014 4:28 pm ]
Motor and lower unit are spotless
Author:  tinman454 [ Sat Feb 01, 2014 7:08 pm ]
Well the drive is good for 50 hrs before it needs to be grease . So every thing should be good how did it look in the bottom of the belt cover? I would say your only choice is to put a zerk fitting in your self. I'am not shure if you can do it with out taking every thing out of the drive tube? Did you take the screw out to see if they put any grease in there? If there is how did they do it?? Also on mine there are some other zerk fittings on the motor where it mounts on the boat are these there?
Author:  msm8281 [ Sat Feb 01, 2014 7:21 pm ]
Fork that^^^^I would make MB cover all under warranty!!! I would not be doing that. they should send you a whole new shaft and outdrive.
Author:  Buzz Killington [ Sat Feb 01, 2014 8:41 pm ]
Author:  jmarsh [ Sat Feb 01, 2014 9:01 pm ]
I gotta buddy that has an old old hyperdrive an his doest have one either but it has one in side the housing you have to pull the prop an shit off to get to it
Author:  Buzz Killington [ Sat Feb 01, 2014 9:15 pm ]
Author:  Buzz Killington [ Sat Feb 01, 2014 9:47 pm ]
Through the power of the Internet
Think on mb website they have the process under hyper service updates
Its a threaded grease fitting
4-6 pumps is supposed to do for 200hrs?? Wtf??
Author:  Buzz Killington [ Sat Feb 01, 2014 9:49 pm ]
Sry 8 -10 pumps....
Author:  Buzz Killington [ Sat Feb 01, 2014 10:04 pm ]
Author:  270Handiman [ Sat Feb 01, 2014 10:14 pm ]
Once a year is about right. What's the issue?
Author:  duckslayer17 [ Sat Feb 01, 2014 10:50 pm ]
Mine is just like that. Take the prop off and the bearing seal at the prop end. Take that little bolt out and replace with zerk... if u just pump with grease it will blow a seal out. Don't ask me how I know.
Author:  Buzz Killington [ Sun Feb 02, 2014 6:03 am ]
Author:  Hernaja1 [ Sun Feb 02, 2014 7:58 am ]
That's in believable !! MB never fails to keep failing ! Lol
Author:  tinman454 [ Sun Feb 02, 2014 9:15 am ]
Buzz does it have zerk fittings on the motor mounts ? Mine has two up there that need grese also one other thing I have done to it is open up the football and put die electric grese on the wire connections on the switch contacts. Water gets in there and freezes. It's prone to corroding inside of there. I also think the salt on the roads helps a lot?
Author:  Migrator [ Sun Feb 02, 2014 10:16 am ]
^ Always take the allen head screw out. I pump grease til it gets clean.
Author:  Buzz Killington [ Sun Feb 02, 2014 11:54 am ]
Author:  Mayhem73 [ Sun Feb 02, 2014 1:22 pm ]
Author:  Prodigy [ Mon Feb 03, 2014 11:37 pm ]
correct........u have to back out that one screw and put a zirk fitting on and fill that way............ carefully
the design was changes several years ago.............
Author:  Buzz Killington [ Tue Feb 04, 2014 4:45 am ]
