It is currently Mon Jul 07, 2025 9:00 am
Reply to topic  [ 7 posts ]
 Prop removal on a Go Devil Surface Drive
Post Prop removal on a Go Devil Surface Drive
Does anybody have any suggestions on the best way to get the prop off? I have got the end nut removed and can not make the prop budge, just trying to make sure I don't damage anything. I have a new prop coming and am looking for any suggestions you guys have.
Thanks
Tue Oct 06, 2009 10:19 am
MMT Moderator
Post Re: Prop removal on a Go Devil Surface Drive
Is it threaded? I just took mine of my GTR and it wasn't threaded. Just a big lock nut and once I removed it the prop came right off.
GTB 1860 w/ 2019 GTR40XD-HO
Tue Oct 06, 2009 10:37 am
Yes it is threaded
Tue Oct 06, 2009 10:51 am
Spray your prop down with a can of freeze off from Autozone and then hit it with a board and hammer and it will come rite off
Ideas not coupled with action
never become bigger than the
brain cells they occupied.
Owner
Tue Oct 06, 2009 11:29 am
I use a large pipe wrench on the inner hex - let it contact the cav plate - then use a 4 foot 2x4 for leverage wedged between a blade and the center threaded shaft - put your weight into it and if it doesn't release - carefully use a propane torch and heat the center of the prop to expand it - but do not heat it too much or you will damage the shaft seal.... Have heard of using boiling water to get same effect and prevent seal damage.... Put plenty of grease on at re-assembly....
Tue Oct 06, 2009 7:23 pm
The freeze off along with a BFH did the trick! Thanks for the info Guys.
Wed Oct 14, 2009 9:07 am
I'm having trouble gettin my prop off on my GDSD. I have tried the freeze off and heating. About how long should I heat up the prop?
Wed Sep 29, 2010 4:27 pm
Users browsing this forum: No registered users and 31 guests
