It is currently Mon Jul 14, 2025 4:30 am
Reply to topic  [ 60 posts ]  Go to page 1, 2  Next
 Prodrive skeg mods
Post Prodrive skeg mods
can anyone post a photo of one of bayouboys skegs?
Sat Sep 28, 2013 6:34 pm
Post Re: Prodrive skeg mods
Sat Sep 28, 2013 6:39 pm
thanks man
Sat Sep 28, 2013 6:40 pm
Sat Sep 28, 2013 6:41 pm
The stock skeg will not have enough meat left on it for a good modification best to start fresh.
Sat Sep 28, 2013 7:41 pm
^^^ listen to this man
Sun Sep 29, 2013 7:02 am
Hate to ask but what's wrong with the stock skeg?
Looks like this one goes further under the prop?
Sun Sep 29, 2013 8:21 pm
Mon Sep 30, 2013 5:24 am
Before (Stock)...
After (BB Skeg)...
35 GTR - 1754 Extreme
Wed Oct 02, 2013 9:32 am
Wed Oct 02, 2013 11:59 am
Just ordered one tonight to replace the cracked stock one. I am hoping this one does well in sand.
Thu Oct 03, 2013 10:49 pm
You will be impressed!
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Thu Oct 03, 2013 10:55 pm
It does much better in sand from what I have seen
16x42 Charles Leonard ... Sold
18x46 Gator Tail w/ 35 gtr stage 1 by hoyt
Thu Oct 03, 2013 11:03 pm
Ran the new skeg this weekend but water was up so never got to run any sandbars with it. I will say that all off the torque steer is gone. We tried all sorts of things with the stock one and nothing ever solved it. Even if there is no improvment in the sand having the torque steer gone was well worth the money.
Sun Oct 13, 2013 7:19 pm
It should do good in the sand. I know it makes a big diffrence in the hard bottom marshes I run and in the veggies as well. U will like it.
Sent from my SAMSUNG-SGH-I337 using Tapatalk [url='http://tapatalk.com/m?id=10']now Free[/url]
Stage 2 36 HP Pro-Drive FPR W/ Bayou Boys Custom Skeg,Cave Plate,and Weed Cutter with MAC Exhaust
Pushing a 17X54 Pro-Drive X-Series boat
Sun Oct 13, 2013 7:46 pm
Need the number for the bayou boys skeg if anyone has it. Have a 2013 36 prodrive was woundering if the skegs are the same it looked like they changed the angle on the top plate of the shaft.
Tue Oct 29, 2013 9:52 am
PM Him,,he will get back with you.
Come to think about it,,,good luck. Its almost holloween, he likes kids/candy and dressing up!!! :shock:
Tue Oct 29, 2013 10:04 am
I might have to make me one of those skegs after all. Just found a nice piece of plate at work that still has the Alcoa wrapper on it. :mrgreen:
Modded 36 PD draggin' around an 1848 PD boat backwards!
Tue Oct 29, 2013 7:25 pm
Tue Oct 29, 2013 9:48 pm
BB, two questions about your skeg design:
1. Do you think a person needs the torque tab for a center console with hydraulic steering?
2. Have you played around with leaving more of a gap on front of the prop like the new Gen III skeg? I like that concept because I think it frees up more "stuff" to get drawn to the prop...mud, water, muck, lilies.
Sent using Morse Code from my not so smart phone.
Tue Oct 29, 2013 10:32 pm
Thanks brother. Seems pretty self explanatory. Now I just wonder how friendly my skep will come off. ???
Wed Oct 30, 2013 4:02 am
Wed Oct 30, 2013 4:26 am
Wed Oct 30, 2013 9:22 am
Wed Oct 30, 2013 9:35 am
GREAT thoughts and comments Will and BB.
Thanks!
Wed Oct 30, 2013 10:21 am
Well, made my skeg last night , hope my wedge is right the first time. Working on a better reverse now. Hope to run it tomorrow.
Wed Nov 06, 2013 1:12 am
Pics or its all bullshit!! :lol:
Wed Nov 06, 2013 5:48 pm
Wed Nov 06, 2013 6:15 pm
I cant wait to try my new skeg . :D
Wed Nov 06, 2013 6:47 pm
I'll try to stick up some installed pics tomorrow. The one handed reverse is the CAT'S ASS!
Hope to test drive Friday.
Wed Nov 06, 2013 7:26 pm
Wed Nov 06, 2013 7:36 pm
Gotta run this skeg and see if I need to make any changes. Since I can't weld aluminum and don't want to trial and error stamping the torque wedge, I made one similar to stock and milled a recess into the skeg and just drilled and tapped the wedge on, 2 thread into the wedge from one side of the plate and 2 more thread into the skeg from the wedge side. I can take it off and mod it or make a whole nother one and replace it. ???
I want to get my buddy to tig on a strip of 1/4" channel on the bottom edge once I get satisfied with the angle. I may trim a little more off.
Had to make all new parts since I didn't want to mod my stock pin. Here's a few pics of the parts and pieces. My stock pin is worn but was just under 16mm. I ended up cutting down a 16mm bolt and used the sholder as the pin, just had to spin it up and clean the edges. Drilled and tapped and used a 10mm bolt, drilled the end and put 4 set screws oposing each other for the hand brake cable. The stock pin had a 3/4 10 thread and I just had to make the aluminum piece to fit it all together. Brain was working hard on this one. I may change it a little if I have problems. Used a 90 degree "noodle" so the cable wouldn't have to go straight in from the bottom. I'll take some installed pics tomorrow. Seems pretty cool in the yard. This is just my first stab at it.
Wed Nov 06, 2013 9:08 pm
You'll like that pin puller a lot. I know I love my setup like that. It still boggles my mind that PD doesn't make this a standard feature on all manual reverse models. The reach around is a pain and the auto reverse is way overpriced!
Wed Nov 06, 2013 9:15 pm
I made a pin puller a while back but with the hand brake and cable you can do it all with just one hand. Faster than the hydro also. You just still look like a wacko ratchet'n around but nobody points and laughs when you hual ass backwards. :mrgreen:
Thanks for the pics Bayouboy. You always inspire me. :mrgreen:
Wed Nov 06, 2013 9:19 pm
Mine
http://youtu.be/tHO8xCmYBNU
Wed Nov 06, 2013 9:27 pm
Any time my boy, Also I modified my turn stops and tweaked the top engine plate to where I can get 2 clicks per push rather than just one. You can literally get it in reverse in 2 seconds.
Awesome work!!
Wed Nov 06, 2013 9:37 pm
What did you make yours out of JLACOUR. Pics?
Damn BB! I wish you didn't tell me that.
Seriously, thanks again for the help man.
Thu Nov 07, 2013 4:15 am
It's Rods from the mmt store
Thu Nov 07, 2013 6:43 am
Ran with new skeg today. Was really impressed by the way it stayed in the grass more instead of popping out. Could run through pretty heavy vegetation at slower speeds too . Nice!
The one hand cable reverse is the CAT'S ASS for sure!
Sun Nov 10, 2013 6:11 pm
Welcome to my world! LOL
Sun Nov 10, 2013 8:40 pm
Users browsing this forum: No registered users and 31 guests
