Mud Buddy 35HD prop removal help please
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=52513
Author:  Cradams10 [ Sat Apr 19, 2014 9:28 pm ]
Post subject:  Mud Buddy 35HD prop removal help please
So after a while of messing with it, I finally got the prop nut off. Boat and motor are new to me so haven't done this before. How do I get the prop off? I'm hesitant to hold the threads tight as I don't want to strip them. Any suggestions appreciated.
Thanks guys.
Author:  Cradams10 [ Sat Apr 19, 2014 9:29 pm ]
Post subject:  Re: Mud Buddy 35HD prop removal help please
Also, anyone know if the nut is supposed to be torqued when put back on? And if so, what size is it? I got it off with a crescent wrench.
Author:  270Handiman [ Sat Apr 19, 2014 9:54 pm ]
If it's a hex shaft....it should just pull straight off....it may take some persuasion. If it's threaded, gotta unscrew it.
Author:  mud slinger 69 [ Sun Apr 20, 2014 5:47 am ]
Should be a hex just hit it she'll come off. When ya put the new one on just tighen it up good prop shouldn't move back and forth.
Author:  Cradams10 [ Sun Apr 20, 2014 8:08 am ]
It's threaded. Turns entire shaft when trying to unscrew.
Author:  GatorDubea [ Sun Apr 20, 2014 8:23 am ]
did you try tapping it with a hammer straight off should be a hex shaft not a threaded
Author:  DmaxHunter [ Sun Apr 20, 2014 8:53 am ]
1 1/16 wrench
Author:  duckslayer17 [ Sun Apr 20, 2014 10:39 am ]
This what I did last time. Go buy u a second nut 7/8 course thread. Put the first nut on followed by the second. You ate using the second nut as a jam nut. Then heat the prop hub up with a tourch. If you are not planning to use that prop again beat it off with a hammer while you hold the first nut only with a 33mm socket.
While u have the prop off make sure u grease the drive. Do so by taking the bearing cap off (reverse thread).
Place a 1/4 #10 zert in the hole on the belt housing side of shaft. Fill till you see new grease come out of the bearings on prop end.
Author:  Buzz Killington [ Mon Apr 21, 2014 6:13 am ]
Author:  Cradams10 [ Mon Apr 21, 2014 10:29 am ]
Thanks for help guys. Rookie mistake. It's a hex. It came off, hopefully prop but won't give me problems next time.
Author:  Buzz Killington [ Mon Apr 21, 2014 4:22 pm ]
Lol
Awesome
