GT 3 Blade Review Thread https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=52525 |
Page 1 of 2 |
Author: | BayouStateHunter [ Sun Apr 20, 2014 9:10 am ] |
Post subject: | GT 3 Blade Review Thread |
09 GTR on an GT 1860CC GT Stage one Deep water I ran 29 by myself at just under 3700 rpms. I used to run the near the same speeds with a fresh 2 blade but at 3700-3800rpms. I can't tell if it vibrates less with the CC set up but it feels like it has a little more low end and reverse is improved. I'll post shallow water speeds and loaded weights at a later date. I just wanted to get the info out there. FYI, the prop did not come with a cup which recesses the nut into the prop. |
Author: | msm8281 [ Sun Apr 20, 2014 9:40 am ] |
Post subject: | Re: GT 3 Blade Review Thread |
Mine diduploadfromtaptalk1398008434380.jpg |
Author: | msm8281 [ Sun Apr 20, 2014 9:51 am ] |
What # is stamped on the blades. Mine is 567.I wonder what it means as for as indentifaction purposes. Btw 3800 with a stage 1 motor seems low with a two blade. I would think you would be around 4000. What does your stage one consist of? |
Author: | BayouStateHunter [ Sun Apr 20, 2014 10:07 am ] |
#567 stamp also. An early Hoyt cam, decked heads and exhaust. I never ran 4000 or over until my 2 blade prop got worn. |
Author: | GatorDubea [ Sun Apr 20, 2014 10:16 am ] |
something isnt right with that motor then because my stock one turns 3800 easy 28mph deep water |
Author: | BayouStateHunter [ Sun Apr 20, 2014 10:20 am ] |
But it will run 26-28 with a 4 man bowfishing load with generator and loaded ice chest. I know it will run faster with the 2 blade probably 30-31 unloaded. Don't forget I'm running a 1860 CC with 2 batteries and some misc equipment weight The motor never reved up high in all the years I had it. My cam is different then the the ones out there now. Not sure if that is the difference. |
Author: | msm8281 [ Sun Apr 20, 2014 10:21 am ] |
Author: | DUCK HEARSE [ Sun Apr 20, 2014 10:34 am ] |
What hole are you running your motor At top middle or bottom |
Author: | BayouStateHunter [ Sun Apr 20, 2014 10:36 am ] |
Middle is the sweet spot for this rig |
Author: | DUCK HEARSE [ Sun Apr 20, 2014 10:37 am ] |
You might try moving it with the new three blade |
Author: | Gameover [ Sun Apr 20, 2014 11:25 am ] |
I run a 1754 xtreme CC stage one and run 4350 Rpms and 31 mph. When I ran 3 blade I went down to 4100 and 29-30 mph |
Author: | dfou [ Sun Apr 20, 2014 1:02 pm ] |
Author: | deltaduckmaster [ Sun Apr 20, 2014 1:15 pm ] |
Their running different gears. I tell you this I know my boat is a dual but I love my 3 blades on it. Not saying it outperforms the 2 blade but it's a better for me and what I do. Sent from my iPhone using Tapatalk |
Author: | BayouBuster [ Sun Apr 20, 2014 1:32 pm ] |
I've been running it for a month or so now and love it, hole shot is better, tiller torque is noticeably less with a load for me. It did fine in thick grass with a light load but with 4 people I had to change back to the 2 blade foe frogging. Sent from my SAMSUNG-SGH-I537 using Tapatalk |
Author: | THE TANK [ Sun Apr 20, 2014 1:56 pm ] |
[quote="BayouBuster"]I've been running it for a month or so now and love it, hole shot is better, tiller torque is noticeably less with a load for me. It did fine in thick grass with a light load but with 4 people I had to change back to the 2 blade foe frogging. ^^^^^^^^^^^^^^^^^^With 4 people I had to change back to the 2 blade foe frogging....... It's NOT all that to me, you lose RPM's and it don't carry a load good I just stick with a 2 blade hands down I rather a 2 blade for performance and all around prop. Sent from da woods! |
Author: | MarshJB [ Sun Apr 20, 2014 3:44 pm ] |
Author: | GatorDubea [ Sun Apr 20, 2014 3:48 pm ] |
2007 is the year for my motor |
Author: | msm8281 [ Sun Apr 20, 2014 3:51 pm ] |
Old gearing will not turn it that good. My stage two with old gearing could only turn it about 4200 rpms. Im upgrading to the new gearing now. I post up the results after its complete. |
Author: | cupped up [ Sun Apr 20, 2014 5:05 pm ] |
2 blade > 3 blade Only thing better about a 3 blade is reverse and you can idle shallower than the 2 blade. Everything else, nod goes to the 2 blade. |
Author: | txmudcutter [ Sun Apr 20, 2014 5:19 pm ] |
i dont have any complaints out of my three blade so far, but i haven't ran a two on this boat yet either. This is a stock motor also and ive seen 30 in deep water light that plenty satisfy s me being a stock motor anyways. Is GT gonna offer both now when you call to buy one? |
Author: | MarshJB [ Sun Apr 20, 2014 5:30 pm ] |
Author: | doubleBanded [ Mon Apr 21, 2014 8:41 pm ] |
I ran one on stock 1852 lost speed. I'll try agian when get stage one |
Author: | bbarras85 [ Mon Apr 21, 2014 8:53 pm ] |
Author: | CAJUN OUTLAW [ Mon Apr 21, 2014 9:09 pm ] |
If the three blade performs close to the same as the two blade, even if its a lil slower... the blades look a lil thicker on the three blade, so it might not wear out ad fast as the two blade. It may be worth a shot for me even though i have old style pulleys. |
Author: | deltaduckmaster [ Tue Apr 22, 2014 7:05 am ] |
Author: | Jamie B. [ Tue Apr 22, 2014 7:34 am ] |
Yep Delta is right, this would help your rig alot with how heavy it is. The new gear does really well in all aspects. |
Author: | CAJUN OUTLAW [ Tue Apr 22, 2014 8:09 pm ] |
Well then....make room...let me know when to bring it. ![]() I have one more week off. |
Author: | Jamie B. [ Tue Apr 22, 2014 8:11 pm ] |
hahahaha |
Author: | CAJUN OUTLAW [ Tue Apr 22, 2014 8:28 pm ] |
The other night I had 6 of us in that heavy rig with the bowfishing gear. It barely wanted to plane in deep water but ran 26-27 in shallow. I think that was the hardest that motor ever worked coming home with all those people,28reds,15sheep head,and 9 drum fish. Got on step and kept it up till back at launch. I think my worn 2 blade actually helped with that big load. And....what the fuk was so damn funny? |
Author: | Jamie B. [ Wed Apr 23, 2014 6:43 am ] |
Bring it over, we will get it done |
Author: | deltaduckmaster [ Wed Apr 23, 2014 11:27 am ] |
Nothing wrong with that. The gears will help you with the loads. Sent from my iPhone using Tapatalk |
Author: | CAJUN OUTLAW [ Wed Apr 23, 2014 10:11 pm ] |
What do I order? Top gear? Bottom gear? What ratio will it change it to? How bout the new trim unit I heard about? Is that in stock too yet? |
Author: | AKA Freshwaterkilla [ Wed Apr 23, 2014 10:17 pm ] |
Bottom gear belt housing and a belt. Gear ratio 1.26 from the 1.18 ratio. Sent from my iPhone using |
Author: | Richard in LA [ Wed Apr 23, 2014 10:37 pm ] |
Author: | BayouStateHunter [ Wed Apr 23, 2014 10:55 pm ] |
For the record, oow Rpm's were a little over 4000. There is some adjusting to be done as it just came from the shop after the rocker boss incident. Still 29 ain't bad. |
Author: | CAJUN OUTLAW [ Wed Apr 23, 2014 10:59 pm ] |
I guess if u gotta get a whole new belt housing to change gears u might as well get the new style lower unit too.?? Do u need to grease and change seals as often with the new style? |
Author: | AKA Freshwaterkilla [ Thu Apr 24, 2014 7:15 am ] |
Author: | txmudcutter [ Thu Apr 24, 2014 7:50 am ] |
Author: | msm8281 [ Thu Apr 24, 2014 7:53 am ] |
Housing is to accommodate larger pulley. Belt is to fit 48t pulley instead of 45t. |
Author: | txmudcutter [ Thu Apr 24, 2014 7:57 am ] |
Page 1 of 2 | All times are UTC - 6 hours |
