GT lower unit rebuild. https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=52886 |
Author: | BayouStateHunter [ Thu May 01, 2014 7:45 pm ] |
Post subject: | GT lower unit rebuild. |
Anybody got any pics of the guts before I crack it open? I got the rebuild kit in and will take a stab at it this weekend. There are a shitload of o rings.... Thread research didn't prove extremely fruitful. |
Author: | BayouStateHunter [ Fri May 02, 2014 6:06 pm ] |
Pulley and taper lock are rusted bad. I out the Allen head screw in the extra hole and it won't back the taper off the pulley. I soaked it in WD40 to no avail. I beat the piss out of it with a plastic hammer away from the prop. Does it do any good to beat the pulley towards the prop or should I be hitting the taper lock only? Also do you leave the Allen screw in while you attempt to get the pulley off? |
Author: | BayouStateHunter [ Fri May 02, 2014 6:22 pm ] |
Post subject: | Re: GT lower unit rebuild. |
Author: | AKA Freshwaterkilla [ Fri May 02, 2014 6:34 pm ] |
No u only hit the pulley toward the lower unit mounting flange and keep tightening the Allen in taper lock Sent from my iPhone using |
Author: | BayouStateHunter [ Fri May 02, 2014 8:20 pm ] |
The bitch is stuck and rusted bad. She's not cooperating. |
Author: | msm8281 [ Fri May 02, 2014 8:26 pm ] |
Heat it up |
Author: | BoatDR [ Fri May 02, 2014 8:41 pm ] |
Author: | AKA Freshwaterkilla [ Fri May 02, 2014 10:33 pm ] |
Author: | BayouStateHunter [ Sat May 03, 2014 6:31 pm ] |
After a lengthy soaking in penetrating oil and a beat down by a new $6.00 rubber mallet. Thanks for the help guys. |
