Greasing a Copperhead?
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=53283
Author:  Kre [ Fri May 16, 2014 11:46 am ]
Post subject:  Greasing a Copperhead?
I just picked up a used 23 HP Copperhead.
How often should I grease the prop shaft?
How many pumps? How do I know when enough, is enough?
Can I use the same marine grease I use on my hubs?
Thanks Fellas!
Author:  Kre [ Thu May 22, 2014 6:58 am ]
Post subject:  Re: Greasing a Copperhead?
Come on....someone's gotta' have some guidance for me.
Author:  DmaxHunter [ Thu May 22, 2014 10:20 am ]
First off I know nothing about copperhead s, but as long as you use a quality marine grease on you hubs yes. As for the prop, depends on the way they are setup, they're not a manual online
Samsung S5
Author:  bengtr35 [ Thu May 22, 2014 10:23 am ]
My first copper head they said do not grease it, My last 12hp I had to grease, My new 18 I have not took it off the pallet and read the instruction to see whats needed. I would call copperhead and check.
Author:  Kre [ Wed May 28, 2014 9:18 am ]
I've called Copperhead twice but I haven't gotten a call back.
Anyhow, there are zerks on the drive shaft. One by the prop and one on each side of the pulley for the belt.
Author:  Puddle jumper [ Mon Jun 02, 2014 12:23 pm ]
one pump of the red CRC marine grease in each zerk every 20hrs.
Author:  Puddle jumper [ Mon Jun 02, 2014 12:24 pm ]
and that's using your standard grease gun....forgot to mention that. Hope this helps
Author:  cheesypoof [ Tue Jun 03, 2014 1:37 am ]
What Puddle Jumper said.... I don't wait twenty hours though. I have a little mini grease gun with marine grease that I keep in the truck and just give it a shot after pretty much every couple hunts because it only takes seconds and I am pretty anal about maintenance. The zerk by the prop takes very little and you can feel the backpressure when it is full. On mine I don't ever get any backpressure on the other zerk so some of it is probably going into the shaft.
