It is currently Sun Jul 06, 2025 5:38 pm
[ 6 posts ] |
mcguigs84
 Engine Push
My engine pushes into me when up on plane, it is a bear to drive. What are some tips and tweaks to balance out that prop torque when running open water? If it is just me in the boat it rolls (as if driving through waves) in calm water, is that normal? I read a triple blade prop helps, is that true?
I run a 1648 weldbilt, 23 hp MBSD with Mikuni carb and after market exhaust. I have the stock prop on still.
I couldn't quite find the right key words in search, so if you know of some good threads that already explored this, please point me to the .
Sun Jun 08, 2014 12:23 pm |
duckduckboom
Joined: Tue Nov 23, 2010 6:33 pm Posts: 5603 Location: Corner of Hell an high water, La
 Re: Engine Push
Weight distribution is paramount when it come to tiller torque
_________________ You have your whole life to be an idiot, take a day off!
Sun Jun 08, 2014 12:32 pm |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
 Re: Engine Push
3 blade is a lot worse on my gtr as far as tiller torque versus my 2 blade
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
Sun Jun 08, 2014 1:29 pm |
flatontheplatte
 Re: Engine Push
Is it square on the transom?
Fri Jun 13, 2014 10:49 pm |
The Hairy Coot
Joined: Wed Aug 28, 2013 10:40 pm Posts: 717 Location: Louisiana
 Re: Engine Push
Couple of things. You can offset your motor on the transom by 1/4"-3/8" to the port side. The other is to adjust the bent portion of your skeg under the prop. If its pushing into you, you may need a little more angle. Take a 2' or 3' piece of 4x4 pine and cut a kerf in the end of it the thickness of the skeg and use it as a wrench to put a little more bend in it.
Sat Jun 14, 2014 5:51 am |
50fps
 Re: Engine Push
Try trimming down a bit or get out the GPS and find the sweet spot, then if you still have tiller torque adjust your skeg.
Sat Jun 14, 2014 2:02 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 72 guests |
