Gtr prop https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=57531 |
Author: | Hebert12 [ Thu Oct 23, 2014 6:05 pm ] |
Post subject: | Gtr prop |
What's the best prop to run on my gator tail with carb and exhaust and about to put cam , my props at 11 1/4 right now is that wore bad bad? |
Author: | msm8281 [ Thu Oct 23, 2014 6:06 pm ] |
Post subject: | Re: Gtr prop |
3 blade 10 pitch. Yea that thing is toast. |
Author: | North LA Hunter [ Thu Oct 23, 2014 6:07 pm ] |
11 1/4 is pretty worn. Either the 3 blade or the stock 2 blade. Sent from my beeper |
Author: | Hebert12 [ Thu Oct 23, 2014 6:13 pm ] |
My old prop I'll run 29 steady bumping 30-31 at about 4100-4250 rpm just got in from running a worked prop with 11 pitch and was running 28-29 best I got was 30.7 but running around 3800-3900 rpms |
Author: | LA Prop [ Thu Oct 23, 2014 7:07 pm ] |
A burnt gtr prop will always run faster than a newer or new prop. If u put the can the 11 pitch 3 blade will be your best bet. You'll get more speed than the 10 pitch 3 blade. |
Author: | Hebert12 [ Thu Oct 23, 2014 7:29 pm ] |
I've just seen a few buddy's with 3 blades that come with the gtr suck in reverse in grass |
Author: | msm8281 [ Thu Oct 23, 2014 7:33 pm ] |
Can't be a pussy with it. Hit it in forward to get the grass off it then nail it in reverse. If the prop ain't spinning fast enough it won't cut it up. |
