Taper lock https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=57826 |
Author: | darrel from meraux [ Wed Nov 05, 2014 11:59 pm ] |
Post subject: | Taper lock |
Anyone have a link to the supplier gator-tail buy's their taper lock pulleys from? I want to try a little experimenting with gear ratios this year. I know the link has been posted before but cant find it anywhere. |
Author: | LA Prop [ Fri Nov 07, 2014 7:43 am ] |
Post subject: | Re: Taper lock |
What gear you looking for |
Author: | DENNYEDWARDS [ Thu Nov 27, 2014 8:45 am ] |
Try Motion Industries or Fastenal Co. Both are Goodyear, Gates belt jobbers and can get the pullys and taperlocks if shaft size is known. Dodge- Baldor Taper lock bushings, on their site they will show which measurements they need to match up to your pully. Think you can order them direct form their web site. Motion industrys head office in Alabama. |
Author: | darrel from meraux [ Thu Nov 27, 2014 10:42 am ] |
Thanks a lot man, after some research I found the actual gear is the same and the tper just had a hole in the newwer models for the screw threads |
Author: | BayouBuster [ Thu Nov 27, 2014 1:46 pm ] |
The newer taper locks have a different size shaft hole as well. Just FYI incase someone need to know for the future. |
