PD trim motor just clicks https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=59659 |
Author: | Swamp Wader [ Wed Jan 28, 2015 7:10 am ] |
Post subject: | PD trim motor just clicks |
Battery connection is good thinking mabe switch connection. Any other ideas? 08' model. |
Author: | Will [ Wed Jan 28, 2015 7:39 am ] |
Post subject: | Re: PD trim motor just clicks |
Rocker switch itself. |
Author: | banded-mallard [ Wed Jan 28, 2015 7:52 am ] |
Author: | Swamp Wader [ Wed Jan 28, 2015 8:08 am ] |
OK . will do. Gonna tear into it today sometime. What wires bypass switch? |
Author: | Swamp Wader [ Wed Jan 28, 2015 8:19 am ] |
Its 3 wire if I remember right. red blue yellow at switch. Different colors at pump so there is a splice. |
Author: | banded-mallard [ Wed Jan 28, 2015 12:33 pm ] |
I have two pumps, one for rev and other for trim. They are trombetta trim solenoids. Here is the wiring diagram of what I have. Trim Solenoids.PNG I modified the existing trim pump bracket to hole both pumps and the solenoids. IMG_2902.JPG IMG_2904.JPG |
Author: | Swamp Wader [ Wed Jan 28, 2015 6:11 pm ] |
hmmm... so still need a new switch also. Same or any winch style switch? |
Author: | banded-mallard [ Wed Jan 28, 2015 9:03 pm ] |
If you put the solenoids, you can put any $10 rocker switch on it and can get them at basically any hardware store. Not as easy with the other switch. Plus by using the solenoid, the solenoid takes all the load, not the switch, so the pump gets full load. |
Author: | Swamp Wader [ Mon Feb 02, 2015 8:22 am ] |
I have a winch solenoid out there in shop but the 3 wire thing has got me confused as far as using it. |
Author: | banded-mallard [ Mon Feb 02, 2015 12:26 pm ] |
Author: | Zeek569 [ Mon Feb 02, 2015 12:30 pm ] |
Author: | banded-mallard [ Tue Feb 03, 2015 5:25 am ] |
Author: | Wilson [ Tue Feb 10, 2015 9:27 pm ] |
Stop making it harder than it needs to be. This works fine for the 3 wire. http://www.academy.com/shop/pdp/t-h-mar ... ch&Ntk=All |
