It is currently Sun Jul 06, 2025 10:27 am
[ 6 posts ] |
Best place to purchase Prop
badhen
I need to purchase a new prop for my '12 Prodrive 36hp. I see that you can purchase new ones from PD, but are there any other options available for "aftermarket" props? Any other advice or things I should consider before buying one is appreciated!
Thu Apr 23, 2015 8:50 am |
GDSArgo
Joined: Tue Dec 03, 2013 12:39 pm Posts: 341 Location: Houston Delaware
 Re: Best place to purchase Prop
If you order one from Prodrive talk to your local prop guy get it sent direct. That way he can do a little needed TLC on it right from the get go.
Sent from the company's iPad while at work
_________________ Dont criticize a farmer with your mouth full
Thu Apr 23, 2015 9:29 am |
BlueShamu
There is the Cleaver...which in and of itself, is not a bad prop. But, just anticipate sending it somewhere to get the tapered hub machined down correctly....and then balanced. Hopkins does a less than desirable job on this which has resulted in some negative (and costly) results for some folks. The 27 HP 3 blade is also an option which I have had good results with load carrying and speed.
Ultimately, whatever you get will probably have to be fine-tuned to suit your set-up, wants and needs....or get different props for different conditions.
Thu Apr 23, 2015 2:00 pm |
BlueShamu
Then, there's this contraption...
Fri Apr 24, 2015 8:02 pm |
brickgw
Looks like something out of a Friday the 13th movie!
Fri Apr 24, 2015 8:08 pm |
BlueShamu
And yes.....it is threaded on the shaft with a tapered bushing. No room for the prop nut, though.
Fri Apr 24, 2015 10:23 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 84 guests |
