Shaft Sheared Off At Bushing
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=60880
Author:  cut'em94 [ Sat Mar 21, 2015 7:22 pm ]
Post subject:  Shaft Sheared Off At Bushing
Anyone have this happen before? Was riding along and next thing I knew I saw my prop sinking to the bottom of the bayou about 10' behind the boat.
Author:  Gigafowl [ Sat Mar 21, 2015 7:27 pm ]
Post subject:  Re: Shaft Sheared Off At Bushing
Hope you found the prop - it costs more than a shaft I bet....
Author:  cut'em94 [ Sat Mar 21, 2015 7:29 pm ]
Sure didn't find the prop. And it was a new one that I started using about halfway through duck season. I keep a spare prop but that didn't help me very much in this case.
Author:  rob_E [ Sat Mar 21, 2015 7:32 pm ]
I had one do that on my old motor but I hit something. I never found my prop either.
Author:  Gigafowl [ Sat Mar 21, 2015 7:34 pm ]
Saw one broke off just like yours at a run - used pushpole to "feel" for it
and owner was able to get it back.... Hope you marked the spot....
Author:  cut'em94 [ Sat Mar 21, 2015 7:36 pm ]
I found it odd that it just fell off without hitting anything. Wasn't sure if this was a common problem or not. Motor has 102 hours FWIW.
Author:  Gigafowl [ Sat Mar 21, 2015 7:38 pm ]
Shaft likely fractured when you hit something and it just took a while
for the fracture to grow enough to shear away....
When seals go bad sometimes you will see a wear ring right where
shaft is broken off....
Author:  WhoDat88 [ Sat Mar 21, 2015 7:58 pm ]
That has happened on every brand motor a time or two. You must have hit something hard at some point.
Author:  DmaxHunter [ Sat Mar 21, 2015 8:14 pm ]
Put a call into GT, how old is the motor
Author:  cut'em94 [ Sat Mar 21, 2015 8:28 pm ]
Motor is about 2 years old. I'm not too worried about it, I figured that it happens every once in a while.
Author:  cut'em94 [ Sat Mar 21, 2015 8:30 pm ]
And yea I've definitely hit some hard stuff with it.
Author:  cb5331 [ Sat Mar 21, 2015 8:37 pm ]
Call them. You'll likely have to pay for the shaft, but they may help you a little with the prop if you just bought it.
Author:  cut'em94 [ Sat Mar 21, 2015 8:48 pm ]
Yea I plan on giving them a call on Monday. They've always been great about helping me in the past.
Author:  Gameover [ Wed Mar 25, 2015 8:41 am ]
i have a 2013/14 motor bought in jan 14 and broke a shaft around 80 hour mark. granted it was only about 7 months old but GT said they had few bad shafts and this was happening and replaced my shaft for free.
Author:  mudxxed [ Wed Mar 25, 2015 12:13 pm ]
What metal does GT use for their shafts?
Author:  NinjaButtpirate [ Wed Mar 25, 2015 6:37 pm ]
Cold roll steel
