It is currently Fri Jul 04, 2025 7:48 pm
Reply to topic  [ 6 posts ]
 GDSD Lower Bushing
Post GDSD Lower Bushing
Checked for play by moving prop side to side and up and down, very little play. According to the Go devil manual you either have to use a special tool or reciprocating saw to cut it out. Once I removed the shaft the bushing just slid right out. No play at all. Question: Does that mean the bushing is worn and needs to be replaced or has anyone else been able to pull the bushing by hand?
Tue Feb 16, 2016 11:55 am
Post Re: GDSD Lower Bushing
I haven't had one come out by hand. I would say replace it since its out. You're probly gona have to ream it when you put in a new one
Tue Feb 16, 2016 2:37 pm
It's an interference fit. You press in the new bushing then size it to accept the shaft. Either use a bushing reaming tool or a good sharp 7/8" drill bit. The shaft should slide in smoothly and turn by hand with little resistance.
-Custom pool noodle
-stage 4 water wings
Tue Feb 16, 2016 6:38 pm
I just slipped the bushing in the housing and it has some play until it is completely seated and then I don't feel any. It definitely looks like the bushing has been spinning in the housing.
Tue Feb 16, 2016 7:10 pm
Tue Feb 16, 2016 7:14 pm
Just be sure that you get ALL the items- you think you'll need- on your order at G.D.
Check out "Joe Guide hunting videos" on YOUTUBE...
Tue Feb 16, 2016 9:07 pm
Users browsing this forum: No registered users and 70 guests
