NegativeNed
Joined: Sun Jul 12, 2015 9:30 pm Posts: 21 Location: South Carolina
 Cracked Prop
Doing my occasional inspection and repairs and discovered a hairline crack on the prop. Is this something I can send off and get repaired or will it only cause more damage in the future and just need to replace it?
_________________ 1754 Gatortrax / GTR 37 EFI
Thu Jun 02, 2016 4:13 pm |
scarygary
 Re: Cracked Prop
I had a 2 blade with a crack in the blade like that. I took a grinder and followed the crack then tig welded it up. It lasted another year, then threw the blade at 4800 rpm and in 3 seconds the vibration cracked the crank case cover and destroyed the clutch. If I had to do it again I'd throw it away
Thu Jun 02, 2016 5:16 pm |
dead animal
 Re: Cracked Prop
if you have never slung a blade off at wfo yet, get ready for some excitement!!!!!! lol
Thu Jun 02, 2016 7:49 pm |
Richard in LA
Joined: Tue Sep 08, 2009 1:58 am Posts: 282 Location: Prairieville, LA
 Re: Cracked Prop
I'd scrap it. The potential damage that a sling blade can inflict isn't worth what you may save. Out of curiosity, is that a 10 or 11 p prop? Can you post a pic of the other side?
_________________ GTR, Waitin' on a DFOU hull
Fri Jun 03, 2016 4:40 am |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
 Re: Cracked Prop
Broken prop=broken LU especially if you have the new cast lower. Happened to me last weekend.
Sent from my SAMSUNG-SM-G925A using Tapatalk
Fri Jun 03, 2016 5:43 am |
MaXXis85
 Re: Cracked Prop
Please post a pic of the Engine side of the prop so I can see how the blades meet the hub
Fri Jun 03, 2016 7:22 am |
NegativeNed
 Re: Cracked Prop
Sat Jun 04, 2016 4:35 am |
HOTSAUCE170
Joined: Thu Jun 05, 2014 11:44 am Posts: 1685 Location: Lake Blackshear,GA
 Re: Cracked Prop
send it to gatortail before you scrap it they will probably help you out on a new prop. it never hurts to ask.
_________________ I named my boat RIANNA cause it gets beat up all the time
Sat Jun 04, 2016 6:16 am |
rubbinisracin
Joined: Sun Sep 01, 2013 1:05 pm Posts: 213 Location: Wake Forest, NC
 Re: Cracked Prop
What number is stamped into that prop?
_________________ 1854 CC backyard build with GTR 37 EFI
Build thread here.. viewtopic.php?f=4&t=66815
Sun Jun 05, 2016 6:42 pm |
NegativeNed
 Re: Cracked Prop
Tue Jun 07, 2016 7:39 am |
rubbinisracin
 Re: Cracked Prop
Oh ok thanks.
Tue Jun 07, 2016 7:47 am |
brstanle
Joined: Sun Oct 05, 2014 12:27 am Posts: 659 Location: SETX/Houston
 Re: Cracked Prop
I'd cut that bastard in half and junk it. Baaaaaaad situation waiting to happen, lucky you caught it!
_________________ 35 GTR w/ 1860 GoDevil "Ironsides"
Tue Jun 07, 2016 2:55 pm |
NegativeNed
 Re: Cracked Prop
Thu Jun 09, 2016 6:58 am |
