Grinding noise when spinning prop
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=41&t=66423
Author:  jlbutler2879 [ Sat Apr 02, 2016 9:59 am ]
Post subject:  Grinding noise when spinning prop
I have a ProDrive with duals on it. The other day I was greasing the motors and noticed that one of the motors props spins smoothly by hand without making any sounds and the other one is a little tougher to spin and makes a slight grinding noise. I am not sure if this is a problem or not but seems like they should both spin the same. Any ideas on what I can check? The motors are 2013 ProDrive 36 long shafts. I do believe they are Gen II lower units.
Author:  Will C [ Sun Apr 03, 2016 12:09 am ]
Post subject:  Re: Grinding noise when spinning prop
Drain the oil in the lower unit and inspect for metal as its drained. Also listen to clutch area.Let us kno
Author:  Will [ Mon Apr 04, 2016 6:59 am ]
clutch disc rubbing, normal...
Author:  jlbutler2879 [ Mon Apr 04, 2016 2:29 pm ]
Author:  Will [ Mon Apr 04, 2016 2:35 pm ]
Author:  jlbutler2879 [ Mon Apr 04, 2016 2:41 pm ]
thanks for the info.
Author:  caddobrook [ Mon Apr 04, 2016 3:22 pm ]
Is it a rubbing noise or a grinding noise?
Slight rubbing noise from clutch = OK
Grinding noise from clutch (or anywhere else) = probably not OK....
Author:  jlbutler2879 [ Wed Apr 06, 2016 12:56 pm ]
Definitely a rubbing noise and not grinding. Does this sound and look normal to you?
Author:  Will [ Wed Apr 06, 2016 1:15 pm ]
Definitely the clutch disc rubbing. Not a lot you can do about it. That one is rubbing a good bit but it should calm down after you run it some more. How many hours on the rig? I would say the average lifespan on those clutches is about 200 hours. Seen some last only 50 though.
Author:  caddobrook [ Wed Apr 06, 2016 1:28 pm ]
1st motor looks a lot dirtier than second motor. Grease build up and such.
It is possible you have some grease or mainly dirt in the grease that has gotten up in there and that is causing some extra noise/rubbing....
Author:  jlbutler2879 [ Wed Apr 06, 2016 1:38 pm ]
The clutch on the second motor failed about 6 months ago and was replaced with a new one. That is why it looks to be in better condition.
As for the grease, should I try to clean it out? I greased the motors about a week ago and that is when I noticed the noise. Not saying that's when it happened but that's when I noticed it. I only put grease in the zerks mentioned in the maintenance manual. Is it a good practice to grease or clean anything else while performing the maintenance. I believe the lower units are Gen II's.
Author:  Will [ Wed Apr 06, 2016 2:01 pm ]
Nah.. Just run it. Crank it now and bump the clutch a few times and see if it clears up.
